size of Rotary Tiller for DK45SE HSK
   / size of Rotary Tiller for DK45SE HSK #1
CMOrr
East Texas
I am purchasing the referenced tractor and wanted to get a rotary tiller. I was considering the Howse RTC 70 (70"). I believe this tractor has a pto hp of 36. Will this tractor handle this tiller? I have been told it should but I thought I would run this by the forum to see what the thoughts are. The following is what is on the Howse website:
Rotary Tiller Section
A-frame and gearbox assembly can be reversed for reverse rotation.
Machine can be offset to either side or center.
A-frame extended for smoother operation.
#4 metric torque limiter driveshaft to protect tractor and implement.
Removable tine shaft and tines.
Adjustable skid shoes.
Model Weight Description
RTC48 647 lbs. 48" Rotary Tiller/ 20-50 hp 6 sets of 4 blades
RTC54 679 lbs. 54" Rotary Tiller/ 25-50 hp 7 sets of 4 blades
RTC62 737 lbs. 62" Rotary Tiller/ 35-60 hp 8 sets of 4 blades
RTC70 780 lbs. 70" Rotary Tiller/ 40-60 hp 9 sets of 4 blades
Thanks for the input.:)
   / size of Rotary Tiller for DK45SE HSK #2
You will be fine.
I run a 72" King Kutter II tiller on my DK 35 with no problem.
   / size of Rotary Tiller for DK45SE HSK #3
You will be fine.
same here, run a 72" on my 45 with no problem, think it would have handled the 81" one I wanted to buy easily.
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2018 Elgin Broom...
2022 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
Cushman Electric Cart (A55851)
Cushman Electric...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
