Tractor Sizing Size of bush hog
   / Size of bush hog #1
Smooth
Alabama
Kubota L2800
I'm thinking about getting a Bobcat Ct 225 (27 hp). I want to know what size bushhog, I have heard to get a 4ft cause a 5ft is to much. And i heard a 5 ft would work, so what do you think. I want a bushhog that won't blog down the tractor.
   / Size of bush hog #2
Not familiar with that tractor is that 27 on the pto? The general rule around here is 5hp per foot so yes you should be fine. I bend the rule and run a 6' on my 28hp (25pto) tractor and it works beautifully.
   / Size of bush hog #3
I have used a 5ft on mine on a couple occasion with out any issue, guess its based on what your cutting and how fast you are trying to go.
   / Size of bush hog #4
I use an old /dull 5' JD on my JD 790 (27 HP), works fine for heavy grass & weeds, haven't had it in "brush" yet. I need to do some work on it & sharpen it up before next year. It was $00, BTW! ~~ grnspot110
   / Size of bush hog #5
You should be fine with either one. Typically everyone uses 5 footers behind 8n's, 9n's 2n's etc. They only make about the same power as you. It just may cause you to have to slow just a tad more in some really heavy stuff vs the 4 footer.
   / Size of bush hog #6
I had this tractor with a 5ft woods brush bull, in the tall (12") swampy grass it gets bogged down in anything but low as well as over any inclines
   / Size of bush hog #7
I have a CT 225 (older 25hp). I have pulled a 5' through high grass and weeds with no problems. I have not tried it in true brush (1"- 2.5"). If you go slow you can probably pull the 5'.
Norm
   / Size of bush hog #8
I use a 5 ft kodiak that I bought from Agri supply behind my 225. I have cut grass and brush and it has worked fine. I run it in M and I have never bogged down. Good cutting.
DG
Chesterfield, VA
   / Size of bush hog #9
And that's 24 PTO HP...ran a 60" cutter behind my 790 for 5 or 6 years....worked fine.
Before I got the 790, I had a 16.5 PTO HP tractor...that same 60" cutter worked good with that tractor too, although I'd take partial width passes on the really thick brush.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A51219)
2016 WESTERN STAR...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A51039)
John Deere 6105E...
