sirius radio question
/ sirius radio question #1
gump341
does sirius work with a AM radio in tractor, can i buy a portable AM/FM radio for the tractor and make it work that way no problems
and if so can i buy normal sirius radio that plugs into cigarette outlet and works with the portable FM radio that i can also move the actual sirius radio from tractor to tractor easy and fast
p.s.my situation-lots of tractors/combines/seeders that i switch back and fourth from daily but all of them only have am, i want sirius for all the them but only want to buy 1
/ sirius radio question #3
I don't have one yet, but my information is that it's satellite radio. You have to buy a special receiver and pay monthly fees.
/ sirius radio question #4
You have to have FM, the receivers will not broadcast on an AM frequncy.
/ sirius radio question #5
Hey gump341, I just wrote you all the details, but either my computer or this site doesn't want to work for me tonight and it all got erased. So I'm sick of typing, so long story short...have you looked into a Sirius boom box. Portable, cheap and take anywhere. I haven't seen any sirius receivers that transmit over am.
I had the fm transmitting, plug into a power point (or lighter) unit in my big truck. That way I could take it in my personal vehicle or travel trailer. They have a switch on them to pick different fm frequencies to use on your radio, so, for example, if you have a local station with a strong signal on fm 88.1 and it overpowers your sirius you could switch to 88.9.
I also bought extra power chords and antennaes, just because I'm a neat freak with my vehicles and I didn't want exposed wires, so I hid them all under the dash, etc. That way I only had to carry the receiver from vehicle to vehicle.
/ sirius radio question #6
i switch my serius receiver between trucks and when in the backhoe i listen through a portable FM unit with head phones. when at the shop i leave it on in my truck and listen through a boom box.
good luck,
how does the boom box work, i would hate to install new fm radios on a whole bunch of tractors just for this, i hate headphones also
also does the fm need to be installed in tractor to make sirius work?
can i have a stand alone portable fm playing on 88.1 in the truck and will sirius work plugged into outlet
/ sirius radio question #9
Any FM radio will work - built-in, boombox, tabletop, home stereo or MP3 player with an FM reciever. The Sirius unit simply broadcasts on a specific frequency - you tune your FM receiver to that frequency and you're good.
I move my receiver between three vehicles and have an antenna mounted in each of them. I also have an AC adapter and antenna mounted in the house and use the Sirius receiver there too.
If you have an input jack (looks like an earphone jack but is an input) on your boombox you can wire it directly from the output on the Sirius receiver and eliminate the need for using FM.
Good luck.
so your saying i can use a basic clock radio with fm and tune to 88.1, then turn on my already installed JUST AM radio in the truck and it would work with the fm clock radio?
also about the antenna, is there a good antenna that will still pick up everything that i can pull off and on roofs easy and fast, instead of installing a whole bunch of them
concerning the boombox, is there a durable one i can use that can work all day using live sirius radio, just bring it with me and put antenna with suckion on the rooftop and thats it?
also would the boombox be durable in a rough tractor and what about speakers?i would like to listen to it like normal radio speakers
p.s.does the boombox use batteries, i would hate to buy a crapload of batteries everyday for it
been looking at this sirius sportster boombox 5 radio, seems to be the best boombox thats also afforable, anyone know anything about it, do i need fm in the radio, or does this come with everything i need, just buy it plug it into lighter outlet
do i need a antenna and if so does it need to be connected to the boombox, or can i buy a magnetic one and just place it on rooftop
seems like the sportster does have built in AM/FM radio, but i heard the static is unbearable, would a fm direct adaptor work, would it elimate all the static
could i plug my boombox into lighter oulet, plug adaptor into boombox, then the other end of adaptor into antenna?
/ sirius radio question #14
There's another way to getting music into your yard work. I'm into light classical music and there's a couple low power FM stations within thirty miles of me. I've been using a worktunes FM receiver headset but the reception is spotty. Sometimes if I move a few feet, a commercial station will overpower the one that I want.
Dishnetwork broadcasts twenty music channels and it would be nice if I could receive those while working outside. But an outside speaker is out of the question.
I considered taping the music and using a portable player, but that's a lot of work to prepare.
Then I considered converting the music to MP3 format and playing it over one of those MP3 players. A lot of work.
What I needed was an audio to FM converter that would broadcast on an empty frequency and give me range to about 600 feet.
Amazon has some of those but the users say that the range as received is 3 to 10 feet. They do go on to say how opening the case and turning a potentiometer will increase the range to 100 feet. That's still not enough.
Then I remembered a kit supplier from my amateur radio days (Ramsey Electronics). He has several models that I think will do the job. The glitch is that they are kits that will take a beginner about ten hours to assemble. Though if you know how to solder, it's a four hour job. I ordered a kit today and after I assemble it, I will post my results in this thread.
I'm anticipating that this item will take my dishnetwork audio and broadcast it on 88.0MHZ FM to give me 600 feet range to my worktunes headset. By doing this I won't have to buy a sirius receiver or pay the monthly fees.
/ sirius radio question #15
Not sure what you mean about the JUST AM radio in the truck. The Sirius receiver only broacasts over FM, but you can receive it on a clock radio (as long as it has FM). I've been known to have mine on and have it playing on three or four different radios (in different rooms) in the house. As a side note, mine is an older Sirius One model and I've heard that they have reduced the broadcast strength of the newer units, but they'll still work fine in a car/truck/tractor.
All of the car antennas that I have are magnet mount. Easy on-easy off.
Can't help with the boombox durability question.
/ sirius radio question #16
I installed Sirius SAT Radio in my tractor as follows:
Installed a AM/FM/CD Head Unit (Radio), speakers, with an auxiliary input ($90 bucks)
Velcro'ed my old circa 2005, externally mounted (magnetized) Auto Satellite antenna on top of my cab.
Ran the Antenna wire into my cab
took my portable Sirius Sportster (circa early 2005 model) from inside my house.
got a mini plug cable (Male plug on both ends)
Plugged one end of the mini plug into the Sportster
plugged the other end of the mini plug into the Aux input of the AM/FM/CD Radio
Plugged the car power cable into my power plug in the tractor
plugged the SAT antenna cable into the back of my Sportster.
Selected the Aux input
Works like a charm - I use it while i am cutting my yard and my neighbors yard.
I still bring the Sportster in the house and plug it up to my audio equipment.
go reuse effort for me as I don't need this unit in my cars anymore.
I hope this helps
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
2013 Kobelco SK26LC (A64126)
2013 Kobelco...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
