Single row or double row planting with SuperA/100
   / Single row or double row planting with SuperA/100 #1
Ramon
NC
Farmall 100
Hi,
I was just wondering what was the most common type of farming with a Super A/Farmall 100-140 type tractor. I know that the Cole type planters were typically one row but I have seen two row versions on a tool bar. Which is the Super A/Farmall 100-140 best suited for and what customizations/equipment are required for either one.
Thanks
   / Single row or double row planting with SuperA/100 #2
My brother-in-law has the two-row on his fast-hitch 140.
   / Single row or double row planting with SuperA/100 #3
I've seen your question on several boards, but since I don't know much about your model tractor or a Cole planter, I probably don't have much to offer you.
Hp wise, 2 rows pulls about as easy as 1. I'm guessing it depends on the crops you want to grow, if you need to cultivate & with what type of cultivator, ans so forth. If you need to chance width beween rows for different crops, 1 row. If everything works at 30" (or whatever the planter is set at) then 2 row.
--->Paul
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
3in Poly Pipe (A49461)
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
