Single row or double row planting with SuperA/100
   / Single row or double row planting with SuperA/100 #1
Ramon
NC
Farmall 100
Hi,
I was just wondering what was the most common type of farming with a Super A/Farmall 100-140 type tractor. I know that the Cole type planters were typically one row but I have seen two row versions on a tool bar. Which is the Super A/Farmall 100-140 best suited for and what customizations/equipment are required for either one.
   / Single row or double row planting with SuperA/100 #2
My brother-in-law has the two-row on his fast-hitch 140.
   / Single row or double row planting with SuperA/100 #3
I've seen your question on several boards, but since I don't know much about your model tractor or a Cole planter, I probably don't have much to offer you.
Hp wise, 2 rows pulls about as easy as 1. I'm guessing it depends on the crops you want to grow, if you need to cultivate & with what type of cultivator, ans so forth. If you need to chance width beween rows for different crops, 1 row. If everything works at 30" (or whatever the planter is set at) then 2 row.
--->Paul
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
2005 Ford F650 Fire Truck (A49461)
2005 Ford F650...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2006 PETERBILT 379 DUMP TRUCK (A51222)
2006 PETERBILT 379...
