Single Hydraulic Line implement for Deere 4600
   / Single Hydraulic Line implement for Deere 4600 #1
dcraytor
Knoxville, MD
Deere 4600
So I recently acquired a Woods D80-2 Bush hog, that has a single hydrualic line for raise and lower rear wheels.
My SCV has hydraulic connections. Do I just plug the single hose into the one hydraulic port and it will work? I'm a little nervous as I have used only implements that had a pair of hydraulic lines.
   / Single Hydraulic Line implement for Deere 4600 #2
Try it, should not be a problem. Can't hurt anything. Likely it is a single acting cylinder and uses the weight of the bush hog to return the cylinder and bush hog.
I use a single acting cylinder to raise my snow plow blade and only use one line to the cylinder.
   / Single Hydraulic Line implement for Deere 4600 #3
No problem at all. The system will go into relief while the implement is lowering, but that won't cause any issues.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
2006 CHEVROLET EXPRESS SERVICE VAN (A59904)
2006 CHEVROLET...
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
VALMAR AIRFLO 8600 PULL TYPE FERTILIZER SPREADER (A60430)
VALMAR AIRFLO 8600...
