Single action cylinder rust prevention
   / Single action cylinder rust prevention #1
Saitcho
Quebec
Kubota B26
Hi guys, I am building a dump bed for a pick-up with a power up gravity down system and I am using a regular cylinder. I will be installing a breather with a filter on the top port but was wondering if I can pour some oil in there to protect against corrosion. I want to pour in a small quantity, extend the ram and whatever stays in will prevent rust. Is that a good idea or will it plug the breather on the long run. Or maybe I can periodically remove the breather and spray some lubricant in there?
   / Single action cylinder rust prevention #2
Crazy brain storming here: What about connecting a hose from the port, directly to the tank, but on the lower side? When the dump bed is going down, it will create vacuum on the cylinder that would pull the fluid from the tank. When lifting the bed, it would just go to the tank naturally. Looks a good rust protection method.
Wont that increase resistance as the dump bed closes?
   / Single action cylinder rust prevention #4
I doubt it would make any difference whatsoever.
Anyway, you can always convert it to a single acting cylinder by removing the piston seals and plug the port you don't need.
The simple breather with a squirt of oil, will probably be more than enough.
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2016 CATERPILLAR...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
