single acting toplink hookup
/ single acting toplink hookup #1
ToddDale
I have a cement mixer with a single acting toplink.
On my old tractor (a Kioti), the dealer hooked it up under the seat. When you locked the three point lift arms with the knob uner the seat, the lever to raise or lower an impliment then controlled the toplink.
Can anyone tell me how to hook up to the under the seat hydraulics on a Kubota 4330 so the toplink will work the same as it did on the Kioti?
Thanks
ToddDale
/ single acting toplink hookup #2
Welcome to TBN:D
Do you have a rear hydraulic remote added to your new tractor? That is the best way to control your cylinder...I am not sure how your dealer got it to work on your old machine-doesn't sound right to me:confused:
Welcome to TBN:D
I have no added remote.
Under the seat (where the hydraulics are for the three point lift) are several plugs. One of them will work my toplink if I can find out which to hook to. Then I simply lock the three point and use the control for the link.
ToddDale
/ single acting toplink hookup #4
My Kama and my wife's Jinma has a feature like that. It's a half remote for using a single acting cylinder. Works just like you describe when a valve is turned. When using it the 3pt won't work and you have to return the valve flow to the 3pt again. Mine has an outlet where I could attach a QD if I wanted.
Thanks for the reply. I went to the local Kubota dealer yesterday and spoke with the mechanic. He said to simply put a tee in the outlet that runs the hose to the bottom of one side of the lift arms and plumb it in from there. He's sure it'll work...... but it seems to me that if the lift is locked, that will be too?
OTOH, I have an outlet that on mine that looks a lot like the one in your photos. If the tee idea doesn't work I'll take that plug out and see what's in there.
ToddDale
Log Grapple (A65640)
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
