Simplest hydraulic question from newbee
   / Simplest hydraulic question from newbee #1
hondarider
I have a Fermec/Terrex 650 skip loader with a few leaking hydraulic hose that I'm aware of. I would like to take care of the small problem before it becomes a big problem.
I don't know anything about hydraulics.
So how do I de-pressurize these hose before attempting to remove them?
Any tips on removing them?
THanks!
   / Simplest hydraulic question from newbee #2
Just relaxing all the cyl is a good start, by putting the valve handles through full motion, should relieve any pressure. Keep in mind that heat can build in a circuit and build some pressure.
Certain pieces of equipment have a hyd accumulator, that stores fluid under pressure, so just be aware of this. It is used to apply brakes or release brakes, or spin hyd starters, etc.
Use a rag over the fittings when removing. Safety glasses, etc.
   / Simplest hydraulic question from newbee #3
Like JJ says...
You will probably find that one end (at least) of the hose has a turnable fitting, the other is attached firmly to the hose. Loosen the turnable one first.
   / Simplest hydraulic question from newbee #4
Always use a piece of cardboard when detecting hidden leaks. Placing a piece of cardboard in front of a leak is better than injecting high pressure hyd. oil into yor hand. This has happend and results in serious surgery to remove the oil.
   / Simplest hydraulic question from newbee #6
Obvious note: Do what J_J suggested with stopped engine.
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
2003 Volvo S60 Sedan (A53117)
2003 Volvo S60...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2005 Ford E350 XLT SD Passenger Van (A53117)
2005 Ford E350 XLT...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
