Simplest hydraulic question from newbee
/ Simplest hydraulic question from newbee #1
hondarider
I have a Fermec/Terrex 650 skip loader with a few leaking hydraulic hose that I'm aware of. I would like to take care of the small problem before it becomes a big problem.
I don't know anything about hydraulics.
So how do I de-pressurize these hose before attempting to remove them?
Any tips on removing them?
THanks!
/ Simplest hydraulic question from newbee #2
Just relaxing all the cyl is a good start, by putting the valve handles through full motion, should relieve any pressure. Keep in mind that heat can build in a circuit and build some pressure.
Certain pieces of equipment have a hyd accumulator, that stores fluid under pressure, so just be aware of this. It is used to apply brakes or release brakes, or spin hyd starters, etc.
Use a rag over the fittings when removing. Safety glasses, etc.
/ Simplest hydraulic question from newbee #3
Like JJ says...
You will probably find that one end (at least) of the hose has a turnable fitting, the other is attached firmly to the hose. Loosen the turnable one first.
/ Simplest hydraulic question from newbee #4
Always use a piece of cardboard when detecting hidden leaks. Placing a piece of cardboard in front of a leak is better than injecting high pressure hyd. oil into yor hand. This has happend and results in serious surgery to remove the oil.
/ Simplest hydraulic question from newbee #6
Obvious note: Do what J_J suggested with stopped engine.
New/Unused SD Lanch EDLL Mini Skid Steer (A61166)
New/Unused SD...
2015 Hyundai Santa Fe XL Multipurpose Vehicle (MPV), VIN # KM8SNDHF2FU114492 (A61165)
2015 Hyundai Santa...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
UNUSED RAYTREE RMBD50 - 50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
Excavator Bucket Attachment (A61567)
Excavator Bucket...
