Simplest hydraulic question from newbee
   / Simplest hydraulic question from newbee #1
hondarider
Bronze Member
I have a Fermec/Terrex 650 skip loader with a few leaking hydraulic hose that I'm aware of. I would like to take care of the small problem before it becomes a big problem.
I don't know anything about hydraulics.
So how do I de-pressurize these hose before attempting to remove them?
Any tips on removing them?
THanks!
   / Simplest hydraulic question from newbee #2
Just relaxing all the cyl is a good start, by putting the valve handles through full motion, should relieve any pressure. Keep in mind that heat can build in a circuit and build some pressure.
Certain pieces of equipment have a hyd accumulator, that stores fluid under pressure, so just be aware of this. It is used to apply brakes or release brakes, or spin hyd starters, etc.
Use a rag over the fittings when removing. Safety glasses, etc.
   / Simplest hydraulic question from newbee #3
Like JJ says...
You will probably find that one end (at least) of the hose has a turnable fitting, the other is attached firmly to the hose. Loosen the turnable one first.
   / Simplest hydraulic question from newbee #4
Always use a piece of cardboard when detecting hidden leaks. Placing a piece of cardboard in front of a leak is better than injecting high pressure hyd. oil into yor hand. This has happend and results in serious surgery to remove the oil.
   / Simplest hydraulic question from newbee #6
Obvious note: Do what J_J suggested with stopped engine.
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
MOBILE OFFICE CONTAINER (A53843)
MOBILE OFFICE...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53473)
GOODYEAR SET OF...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2025 K3325 UNUSED Double Garage Steel Barn (A53117)
2025 K3325 UNUSED...
2012 SHOP BUILT  TANK MANIFOLD (A53843)
2012 SHOP BUILT...
