Simple backhoe thumb
/ Simple backhoe thumb #1
Volp
Stockholm and Raskarum, SWEDEN and Porreres Mallor
Massey Fergussom MF35, Kubota B6001, JD LX186 Lawn tractor. Ford Super Dexta 3000
I have made a simple thumb for my backhoe using bits and pieces from my local scrap yard. I replaced the bucket pin with a longer with the same diameter (30 mm). I found two ends with 30 mm holes and welded them to two 10 mm thick straight sidepieces. The side are connected by two 15 mm bits as you can see in the pictures. An old top link is fitted between the thumb and the dipper arm. The thumb can be folded to the dipper arm.
I have been using it for lifting heavy rocks as you also can see.
/ Simple backhoe thumb #2
Nice job! I like the top link feature. I made mine a little different with 2 settings, but I might just try your method if I need more adjustment.
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2012 MERTZ ART. ARM MANIFOLD TRAILER (A67714)
2012 MERTZ ART...
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
PORTAPOTTY (A67714)
PORTAPOTTY (A67714)
2025 24in Bucket Mini Excavator Attachment (A66734)
2025 24in Bucket...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
