Simple backhoe thumb
/ Simple backhoe thumb #1
Volp
Stockholm and Raskarum, SWEDEN and Porreres Mallor
Massey Fergussom MF35, Kubota B6001, JD LX186 Lawn tractor. Ford Super Dexta 3000
I have made a simple thumb for my backhoe using bits and pieces from my local scrap yard. I replaced the bucket pin with a longer with the same diameter (30 mm). I found two ends with 30 mm holes and welded them to two 10 mm thick straight sidepieces. The side are connected by two 15 mm bits as you can see in the pictures. An old top link is fitted between the thumb and the dipper arm. The thumb can be folded to the dipper arm.
I have been using it for lifting heavy rocks as you also can see.
/ Simple backhoe thumb #2
Nice job! I like the top link feature. I made mine a little different with 2 settings, but I might just try your method if I need more adjustment.
1991 BRENNER TANK TRAILER (A67714)
1991 BRENNER TANK...
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A67714)
2012 WESTERNSTAR...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A66734)
2019 Cub Cadet...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
