Silo Art
   / Silo Art #21
I'm kinda slow...… Just dawned on me you are talking about letting the camera ride the kite string!!!! :)
   / Silo Art
To add to this I use a 9' kite, gets everything up with no problems, just a standard delta pattern with one line, there is a variant which is like a box kite within a delta, it has a name but I cannot recall it but they are considerably more $$$$$$$$$.
I found 6' was not quite enough and although only a Gopro it felt the load.
Delta Conyne is the delta box configuration.
   / Silo Art #23
I havebeen down the KAP (Kite Aerial Photography) track and found it was very bouncy, a shock cord helped a little but I found the Picavet essential.
Also found that the further down the line the camera was the less pronounced the shock from gusts etc.
I use a Gopro and a Panasonic and for stills they are good and both can be set up for XX frames per minute, I used every five seconds for stills.
Thanks!
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
Delta Consolidated Fuel Tank 48000 (A51039)
Delta Consolidated...
