Silicone Spray - Not Sure if It Is
   / Silicone Spray - Not Sure if It Is #1
MarkF48
Massachusetts
Mahindra 2216
For years I had bought CRC Heavy Duty Silicone Lubricant spray for a variety of uses. Sprayed on, it left a slick surface, but not appearing wet. Lately I haven't found it at my usual locations and online it seems to be around $21 online for an 11oz can (used to be about $4-5). I just bought a couple cans of Blaster Silicone Lubricant and it's not anywhere like the CRC I was used to. The Blaster when sprayed to a surface leaves a wet film and has a oil type odor similar to WD40. I had seen some reviews on Amazon saying the Blaster Silicone spray had petroleum distillates in its mixture, so I looked up the MSDS sheet on it and found it is a formulation of Petroleum distillates hydrotreated light, Alkanes, C9-11-iso- (a paraffin compound I think), and Carbon dioxide. No mention of silicone in the Blaster mixture. CRC and a few others I have subsequently looked at have poly dimethylsiloxane which I believe is the silicone component. I had been using the CRC on rubber and some plastics, but not sure a supposedly silicone spray with petroleum contents would be safe, particularly on rubber such as vehicle door and window seals. Do manufacturers have to list all chemicals in their products on an MSDS document or can they omit some?
   / Silicone Spray - Not Sure if It Is #2
What I have always looked for is “100 % silicone”.
Jack
   / Silicone Spray - Not Sure if It Is #3
I like the CRC stuff too. But a quick search finds it at AutoZone for $7. Maybe try some different on line retailers? Also they have regular and food grade, which costs more.
   / Silicone Spray - Not Sure if It Is #4
I would not use a lubricant containing petroleum products on plastic as a general rule as many are harmed by oils. I use the CRC silicone as well, along with PTFE dry film sprays on plastics. I use the SuperLube equivalent on metal surfaces, as it is silent on ingredients, other than VOCs<60%, but heptane >40% and acetone >25%...:rolleyes:
All the best,
Peter
   / Silicone Spray - Not Sure if It Is #5
The 7.5oz is at O'Reilly's and Napa for $7 as well..
Hydraulic Spray Boom (A50121)
Hydraulic Spray...
2007 Ford Ranger Ext. Cab Pickup Truck (A50323)
2007 Ford Ranger...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2010 International 4400 National Crane 300C 56ft 8 Ton Crane Truck (A50323)
2010 International...
