Signatures
/ Signatures #541
When I first saw your name "rockinmywaypa" I thought you lived in Pennsylvania /forums/images/graemlins/blush.gif, then I saw you are a little further north! /forums/images/graemlins/smile.gif
/ Signatures #542
new signature
/ Signatures #543
new sing.
/ Signatures #544
newer sing.
/ Signatures #545
Floyd R. Turbo
/ Signatures #546
sig.
/ Signatures #547
TS-A
/ Signatures #548
An upload
/ Signatures #549
another.
Guess I don't get it yet...
/ Signatures #550
Michigan
/ Signatures #551
Trying to change my user image.
/ Signatures #553
<font color="blue"> Trying to change my user image </font>
There a place under your personal settings (via My Home) that allow you to upload a photo without having to post it in a thread. Once uploaded ALL your past posts will have the new picture -- same holds true for your signature text.
/ Signatures #554
New Picture for my posts
/ Signatures #557
No need to keep adding posts. Once you change your signature -- every post you have made in the past will show your change.
Are you trying to do this?
... or do you want a photo to be placed in the left column (e.g. My headshot)?
/ Signatures #558
I can't get my picture small enough to fit and still beable to see it. I'm using microsoft paint.
Also, don't you need the correct image here in order to have it on your signature?
/ Signatures #559
I'd like to put it at the bottom where the 3430HST / LA723 is. Just like birds bald eagle.
/ Signatures #560
Here's an 80x80 image -- which is small, so I did not include the entire tractor. You can use this as your avatar, photo, thumbnail, or whatever that 80x80 image is referred as.
Personally, I'm not a fan of putting pictures at the end of posts as a signature. But every image you have uploaded so far will work -- you just aren't using the image tag properly or have included too many characters in your signature.
{image}http://address-of-picture{/image} Just replace the {} brackets with [] ones.
New Quick Attach Hay Spear (A65563)
New Quick Attach...
2013 ALLMAND MAXI-HEAT MH1000 HEATER (A68842)
2013 ALLMAND...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A69167)
2016 INTERNATIONAL...
2016 FORD F450 CREW CAB SERVICE TRUCK (A69167)
2016 FORD F450...
