Signatures
/ Signatures #422
Don, it would be good if you edited your previous post to remove the huge picture. Attached, and here, are smaller versions.
/ Signatures #423
Mike,
I lost a lot of resolution when I reduced it down to 5kb. Any way to do it and maintain the sharpness?
/ Signatures #424
How big is the original?
BTW, the reason you should delete the image from your previous post is that it causes all the messages in this forum to widen which forces people to page left and right to read the posts.
/ Signatures #425
Mike,
I'm confused...I deleted both posts but the large picture frame remained?
It was 42kb(96dpi). I resized it in irfanview to 640x480 to get below 5kb. I recreated it, saved it at a higher resolution 300dpi - 285kb.....then....resized it in irfanview. I think it will be a little sharper. I can't figure out how to crop it to eliminate the surrounding blank paper.
/ Signatures #426
<font color=blue>I'm confused...I deleted both posts but the large picture frame remained? </font color=blue>
Muhammad, can you assist with getting rid of the frame?
<font color=blue>I can't figure out how to crop it to eliminate the surrounding blank paper. </font color=blue>
If it were square it'd be no problem, but the corner detail makes it hard. What about a transparent background?
/ Signatures #430
Morning, Don, attached and below is your file minus almost all the white area.
/ Signatures #432
Minus most of the white area.
/ Signatures #434
Minus white area.
/ Signatures #436
I changed my signature to yours. Looks OK to me.
/ Signatures #437
I switched my signature back to my regular one.
/ Signatures #438
the attachment works...
/ Signatures #440
ignore please
