side to side leveling bush hog
/ side to side leveling bush hog #1
GodfreyDaniels
stanfield, nc
John Deere 4400
Just dumped my tiller for the season and attached the bush hog on my JD4400. Now the hog is significantly higher on the right side. I'm stumped.
/ side to side leveling bush hog #2
There is an adjustment bar attached to the lift arm on the right side most likely a screw type. You can adjust that side to be level with the left arm.
/ side to side leveling bush hog #3
Adjust your 3ph lift arms.
The bush hog was crooked laying on the ground when I attached it. Could it be that the hydraulic arm just picked it up from there? Perhaps I need to put it on level ground and reattach from level? It was level last season and I wonder why it isn't this season.
/ side to side leveling bush hog #5
It's probably not level because the 3pt arm that has the adjusting screw moved do you. Do what KYDan said and adjust the screw on the 3pt arm until it is level.
/ side to side leveling bush hog #6
Do you have a hydraulic side link?
The side links are the only thing that control if the attachment is level.
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
2013 MACK PINNACLE (A65643)
2013 MACK PINNACLE...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
New/Unused Hydraulic Hay Bale Squeeze (A65579)
New/Unused...
2019 K&K Trailer, VIN # 1K9PE2027KA175461 (A65563)
2019 K&K Trailer...
John Deere 4955 Tractor (A66285)
John Deere 4955...
