3-Point Hitch Side link clevis pin falling out
/ Side link clevis pin falling out #1
SouthernSooner
Tecumseh, ok
Kioti DK45 HSE
The left side lift arm clevis pin on the U shaped linkage that attaches the to the frame keeps falling out. Twice while mowing today, the clevis pin has fallen out. And last year it happened a couple of times. Any reason why this is happening? image.jpeg
Kioti DK45 HST
Thanks
/ Side link clevis pin falling out #2
I had that happen to the pin holding one of the lower lift arms (a minor disaster!). The hypothesis for this was a stick hooking the pin out. That shouldn't happen in a hay field, though. For these parts that are (almost) never removed, I'd suggest a bolt or a cotter pin; my lift arms are bolted on, now (I'll have to look at the attachments for the stabilizer arms, since having one of them drop would not be good, either).
/ Side link clevis pin falling out #3
Had one fall out a couple weeks ago on the Quick Attachment (at the ball joint) while using the Box Blade. ???? Never had that happen before. Luckily I had a spare with me at the time. And luckily I found the pin that it that held it all together.
/ Side link clevis pin falling out #4
First of all do we assume the OP had a standard hair pin cotter pin in?
Bolts and cotter pins will do, so won't bailing wire, but if you want something you can quickly take off with one hand try some Rue-rings
/ Side link clevis pin falling out #5
Never had that happen. Have had something pull the cotter pin off the drawbar pins though. I'd try a pin that doesn't come off so easily. Go down to TSC and take a look at their pins, you'll probably find something.
Hate to think of the pain it must have been to get the thing back together with the mower on.
Thanks guys. I did replace one pin with a bolt and need to replace the others. I was really curious why the four or five times a pic fell out, that is was the left side.
/ Side link clevis pin falling out #7
If the pin in the picture is the one that keeps falling out, I would say that it is to long for the application and if it slides to the center of the tractor it puts the hairpin clip in no mans land to be snagged and pulled. The bolt with stop-nut will definitely cure your headaches.
/ Side link clevis pin falling out #8
I have had many times while brush hogging in the woods. I now use wire to hold in all of the pijs. Lesson learned....
/ Side link clevis pin falling out #9
Would anything bad happen if you pushed the hairpin all the way in as far as it would go and let it swing down?
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
2015 LeeBoy 8510C Asphalt Paver (A61572)
2015 LeeBoy 8510C...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
2018 INTERNATIONAL LT625 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 INTERNATIONAL...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
1993 Ford F-150 Ext. Cab Pickup Truck (A61573)
1993 Ford F-150...
