Sickle on a BX2200?
/ Sickle on a BX2200? #44
I already did, but it's a Haban $1,300. Unsure if it's a smart buy because I don't know if parts are still available.
I am out on Haban. I am like you, I don't know where to find parts? Ken Sweet
/ Sickle on a BX2200? #45
If there is a kit or anything that can be fabricated to let a IH, Ford, NH, Massey, Deere, etc. belt drive mower have its full 90 degree vertical and 70 degree below horizontal range of movement, I would like to see the design. Ken Sweet
In my case w/the L&G tractor (WheelHorse) and mid mounted SBM, I'm using an approx 5" length of chain to attach the bar to the cylinder ram and I can get about 35 degree down angle and a full 90 degree up angle. The throw on the cylinder is such that once the SBM's bar is on level land and resting on it's depth shoe, it'll extend out a couple more inches, this and the slack in the length of chain allows the bar to ride over rises and drop with the terrain plus give it the down angle past level. The road bank I mow is an approx 45 - 50 degree up angle and the pond bank is an approx 20 degree down angle at points.
I don't know if this type of setup would work w/a larger 3ph mounted SBM and I'd imagine there would be alot of trial and error in getting a cylinder w/enough throw but one "may" be able to get some hydraulic functionality, except in the extreme angles. Course it may not be enough for the OP's need.
My interest in this thread is based upon possibly adding a SBM to my BX23 as parts for the SMB I'm currently useing are very few and far inbetween. And the SBM is definitely the tool for the job of mowing banks :D
Also I incorrectly indicated the SBM was a 5' when it's a 50". Sorry for any confusion.
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
1984 Cab Over K100 Big Cam 350 (A62613)
1984 Cab Over K100...
Steiner 450 (A64126)
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
