Sickle Bar Sickle bar mowers
/ Sickle bar mowers #1
Solo
Platinum Member
Fairmont,WV
New Holland Boomer2030
I have started looking for a sickle bar mower for my TC18. I called a local dealer for a price. That was all well and good but then he told me they were putting 5' sickle bar mowers on BX1800's. Has anyone done this? I only wanted a 4'6" or smaller for my TC18.
Solo
/ Sickle bar mowers #2
Solo,
I got my information from Befco today. They say 20HP and up for the 5' & 6' mowers. My research is telling me that it seems like the newer Sicklebar mowers are very uesable on our size tractors. Weight for the Befco mower is between 400 to 500 pounds. Good Luck Kent
/ Sickle bar mowers #3
18 rounds up to 20, especially since the tractor is the same "chassis" as the TC21.
That seems very heavy for something that consists of a pto shaft, gearbox & a 5' bar. Is it going to tip our little tractors over?
/ Sickle bar mowers #4
I've got two local dealers , who have deal in them. I'm going to go take a look at them maybe even today. When the mower is in the up position, from the picture it looks like the weight could be pretty well evened out. And when the arm is down if I'm not mistaken, there is a skid plate that rides on the ground to support the sickle part. I may be wrong, but I will know better when I actual see one. Good to hear from you. Kent
/ Sickle bar mowers #5
I have a TC29D which weighs around 2500lbs and a Ford model 515 sickle mower with a 7' cutter bar which weighs around 500lbs, so the tractor weights about 5 times as much as the mower (I’m rounding everything to the nearest 100lbs). It handles it easily, but wouldn't want to go any heavier. It can get a little squirrelly on steep hills.
According to my NH brochure on Boomers, the TC18 weighs around 1400lbs, so if you used it with a 400lb mower the tractor would only weigh about 3.5 times as much as the mower. It's true that part of the mower rides on a skid plate on the ground, but there are times you need to pick up the bar to get over obstacles and transport it. I think it would be a good idea to get a mower well under 400lbs for a TC18, unless you add a few hundred lbs of weight to the tractor.
/ Sickle bar mowers #6
<font color=blue>I think it would be a good idea to get a mower well under 400lbs for a TC18, unless you add a few hundred lbs of weight to the tractor.</font color=blue>
Good Point Mosey
Tractor 1400
loaded tires 300-400 (for both)?
MMM 400
Loader (empty) 600
Total 2800
Not too hard to make it heavy
Steelfan, you're going to bring one home to demo right? We want pictures, especially if you tip over/w3tcompact/icons/wink.gif Be sure to wear your seatbelt.
/ Sickle bar mowers #7
<font color=red>Tractor 1400
MMM 400
Loader (empty) 600
Total 2800</font color=red>
I'd say you're good to go!
/ Sickle bar mowers #8
I've been following this post and the sickle bar mower sure seems like what I need. I have a 500' front ditch and a pond to cut around. The rotary mower on an arm would be good, but all that I find are extremely large in size and price.
/ Sickle bar mowers #9
The only things I have to add are: get a scissors action which means both the guards and knives move and get one with a hydraulic cylinder to adjust the bar angle during operation.
The scissors action does a much better job than a machine in which the guards are fixed and only the knives move.
The hydraulic models allow you to mow at any angle from 90 degrees above horizontal to some angle below horizontal for use on ditch banks.
The Italian models have skids at both the bar end and the tractor end. As was posted you will have to completely lift the mower at times to clear obstacles. Some of the manufacturers supply an extra blade with the mower which is a real plus if you do a lot of mowing. Keep in mind a foreign made machine will be metric so it might be good idea to get the dealer to thrown in a box of knives and a box of rivets if they don't stock those parts.
I've found blade removal is a fifteen minute deal if you have the correct metric wrench and hex key.
/ Sickle bar mowers #10
Hi Fly_Rodr, and all
What I've learned so far about Sickle Bar Mowers, is that they will be perfect for my use. Creek Banks, Ditches, pond sides, and along road sides. My TC21D weights 2500 to 2700 pounds with FEL, MMM, and loaded rear tires. I'm told that HP would not be a problem with the newer, smaller Mowers. As of now Sweet's Tractors has a 5 1/2 ft Super 65 Sickle on Ebay for $1400 and a used 7 ft NH 451 which is being auctioned ,bid is now at $122.50. I'm told they are great to deal with. Also there are a couple other companies who make Sickles listed below.
Befco : www.befco.com
New Holland: http://www.newholland.com/na/Products/Sicklebar.html
Massey Ferguson: http://www.masseyferguson.com/
Kuhn
Sitrex : http://www.sitrex.com/siklebar.HTM
Tonutti : http://www.tonutti.com/
I'm still looking for a used one, but since I've been on vacation, I cleaned the creek bank off with my Gas Powered Weedwacker. It was quite a job. So I'm not in a hurry, I'm waiting for the right mower at the right price.
Hazmat,
You better believe that you would never see pictures if I tip over. I hate to admit when I'm wrong. /w3tcompact/icons/laugh.gif Really the weight with everything on the tractor should be enough to stop such a thing from happening. Great to hear from you.
Kent
/ Sickle bar mowers #11
First Choice offers a 5ft and a 7ft Sickle Mower which comes from Italy. Very reasonable price compared to other units I checked, such as Beefco. I have one on order with them but they are currently out of stock (at least the 7ft'er) but have a new shipment on the way soon. I will use mine for cutting around my 10 acre pond mostly.
/ Sickle bar mowers #12
Hi JerryT,
Where did you order your First Choice at? Also would you mind giving us an idea of price? Thanks for the info.
Kent
/ Sickle bar mowers
I still haven't found a sickle for mine yet .I'm sill looking through the web. There was a good point made about the weight of the tractor, and being shakey on hills. Well that is my main concern. I do have the rears loaded,but no FEL. The reason I started this thread is because my wife wanted me to get one,(I love my wife) until she found out the price.
Solo
/ Sickle bar mowers #14
<font color=blue>The reason I started this thread is because my wife wanted me to get one,(I love my wife) until she found out the price.</font color=blue>
Want to trade? Every time I mention something about any kind of implement, she frowns and says, I suppose you "need" one of those too. I took the attached picture of a cool dump cart on my honeymoon. She actually put it in the scrapbook with the heading "Steve needed a closeup of the dump cart so he can build one someday"
/ Sickle bar mowers #15
Anyone seen any that would work off the mid mower attachment of a NH 33D? It would be nice to have both my hog mower and a sickle bar when making the rounds.
/ Sickle bar mowers #16
Kent
You can see the mower on the FC www site at firstchoiceequipment.net. I would recommend that you call them (252-293-4700). I know they are out of stock on the 7ft mower but have a new shipment on the way. When you call try to talk with Pieter. He is a little hard to get a hold of these days because they are so busy but he will take care of you.
/ Sickle bar mowers #17
Thanks JerryT,
I looked at the site already. Pretty much looks like the Befco. I'd be more interested in the 5 ft mower to use with my TC21D. Thanks for the site, and reply.
Kent
/ Sickle bar mowers
Kent
I think that Tonnutti would be the best bet for a mower 5' or under. The smallest one weights in around 356#. That's about what my Bushhog SQ420 weights. I'm not sure how it would handle on a slope just have to be careful. Another thing would be finding a dealer and cost. At one time I priced one through a wholesaler and it was going to be around $3600.
Solo
1992 International 4700 1,200 Gallon Fuel Tanker Truck (A66736)
1992 International...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
PALLET OF MISC WHEELS (A67714)
PALLET OF MISC...
2010 Honda Civic Sedan (A66738)
2010 Honda Civic...
Evinrude Johnson 3x13.75x13 Aluminum Marine Motor Propeller (A66734)
Evinrude Johnson...
2025 Auger with Bits Mini Excavator Attachment (A66734)
2025 Auger with...
