Sickle bar mower
   / Sickle bar mower #11
FWIW...Not sure about other brands but some parts for Massey Ferguson bars (like the 41) are not available...improvisation is required...
   / Sickle bar mower #12
Keep extra hand file hammer wrenches etc. in your tool box and stick make objects also be twice as careful when cutting around old fence line.
Check out equipment auction ask some folks for there thoughts.
   / Sickle bar mower #13
Talking about a sickle bar mower main points to check
Is the sickle bar straight not twisted how badly are the sickles broken bent is the ball worn where the pitman arm attaches the long slot that the sickle bar slides into is smooth you should be able to move the bar back an forth by hand
   / Sickle bar mower #14
Knowing about sickle bar mowers has any one ever converted one to hydrilic drive using a hydrulic motor
   / Sickle bar mower #15
I guess you could convert one. Just not sure why.
Sickle mowers are high maintenance. Especially when used to trim roadbanks, fencerows, pond banks, etc. Constantly cutting thru debris.
If you logistically have a need for one they are worth the effort. If it's just a novelty, you'll get over it real quick.
I gave $150 for my Ford belt drive. I use it once or twice a year.
   / Sickle bar mower #16
Couple of years ago, I found a JD #9W. It needed a few new guards and sections. It cut OK. After replacing all the sections, it cut just fine. Also found a #9, same as the 9W, just not offset as much. Last spring I replaced all the guards and sections on one cutter bar, it cuts MUCH better. Now I've got a complete spare cutting bar/knife and pitman assembly. Sickle bar mowers are a chore to initially set-up and adjust, but after that, the maintenance is fairly easy.
   / Sickle bar mower #17
Yeah, you want a belt driven one. I looked into it years ago. Shop carefully. One popular unit was called the family something, because apparently it took the whole family to put it on. Not something I would be interested in. I finally bought a hydraulic one, but it's more for trimming than haying or field cutting.
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A55973)
2015 GMC 3500 HD...
SCAN TO RECEIVE TEXT UPDATES (A52708)
SCAN TO RECEIVE...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2013 John Deere 824K Wheel Loader (A56435)
2013 John Deere...
2007 Ford E350 (A55973)
2007 Ford E350...
