Sickle bar adjustment...getting hay to fall backwards
   / Sickle bar adjustment...getting hay to fall backwards #1
blaze 57
Trying to figure out my new sickle mower. My old 350 Deere the hay would always fall backwards no matter how it was adjusted.. This Sitrex double action seems to be a little more finicky about this. Are you suppose to angle your bar upwards towards the sky to get it to fall backwards? thanks in advance
   / Sickle bar adjustment...getting hay to fall backwards #2
Try driving faster or increase knife speed
   / Sickle bar adjustment...getting hay to fall backwards #3
I believe you are. The bar should lean back about 10 degrees. This also helps the rock guards ride up over hidden objects.
   / Sickle bar adjustment...getting hay to fall backwards #4
Is the knife registered? Should never point below flush, if you have heavy thatch try tilting it up until it runs easy.
Yep! angled up must better. Thanks for the replies here!!
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
2014 Ag Spray Schaben Sidedresser (A51039)
2014 Ag Spray...
