Sickle bar adjustment...getting hay to fall backwards
   / Sickle bar adjustment...getting hay to fall backwards #1
blaze 57
Trying to figure out my new sickle mower. My old 350 Deere the hay would always fall backwards no matter how it was adjusted.. This Sitrex double action seems to be a little more finicky about this. Are you suppose to angle your bar upwards towards the sky to get it to fall backwards? thanks in advance
   / Sickle bar adjustment...getting hay to fall backwards #2
Try driving faster or increase knife speed
   / Sickle bar adjustment...getting hay to fall backwards #3
I believe you are. The bar should lean back about 10 degrees. This also helps the rock guards ride up over hidden objects.
   / Sickle bar adjustment...getting hay to fall backwards #4
Is the knife registered? Should never point below flush, if you have heavy thatch try tilting it up until it runs easy.
Yep! angled up must better. Thanks for the replies here!!
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
JCB 505-TC 4x4 Rough Terrain Telehandler (A49461)
JCB 505-TC 4x4...
