Shuttle shift/ reverse problems
/ Shuttle shift/ reverse problems #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
I have a Farmtrac 300DTC and when shifting the shuttle lever to reverse it grinds really bad so I back off, tractor stopped moving, clutch depressed and slowly pull on the shuttle shift lever for reverse and it will go in but will not stay in reverse unless I hold the lever back. The clutch does not slip at all and I have no problem going forward with the shuttle. Could this be a linkage problem, I hope?.
Thanks for any help. Last thing I want to do is tear up the syncros or gears.
/ Shuttle shift/ reverse problems #2
Sorry but it sounds as if the syncronizers in reverse on the shuttle are TOAST
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
(3) 17.5-25 industrial tires on Deere 14-lug grader rims, Coal Valley, IL (A65640)
(3) 17.5-25...
Bush Hog 176 3Pt Blade (A66408)
Bush Hog 176 3Pt...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
