My parking brake fell off, that pin came out of the mount. So I took the floor board off and removed the floorboard mount to reweld the pin. While I had it off, I noticed that that roll pin on the shuttle shift lever had worked it's way almost all the way out. So I tapped it back in with a small hammer. I then noticed that the lock nut on the shuttle shift rod was loose as was the center adjuster (looks like a tie rod adjuster). I turned the adjuster (by hand) until most of the play was gone. Of course you know what comes next...
Now the shuttle shift won't go into reverse. It worked before I took the floorboard off and played with the mechanism. I tried loosening the center adjuster back to where it was before but it still doesn't work, I tried adjusting the cable a half inch both ways and no luck.
I can shift into forward and neutral and the shifter feels much better then it did before but no reverse.
1) Shuttle shift worked before I gently tapped in the roll pin
2) The mechanism isn't hitting anything
Lets suppose I had a new tractor out of the crate, how would I properly adjust the shuttle shift the first time?
Any suggestions?
Any suggestions?
