Shutting Off The Heat In A Cabbed Tractor
   / Shutting Off The Heat In A Cabbed Tractor #1
Ductape
Elite Member
Central New Hampshire
Kubota B3030HSDC
I've noticed when I am running my A/C in the summer, I can still feel a little warm air coming out of the defroster vants over the windshield. Though the A/C still makes it comfortable in the cab, I'm thinking the A/C would be more efficient (cooler) if I stopped the coolant from circulating through the heater core in the summer. The simplest solution I see is to install a ball valve in one of the heater hoses... possibly right at the nipple the hose slips over. Anyone have thoughts on this? Am i on the wrong track?
   / Shutting Off The Heat In A Cabbed Tractor #2
I think you are on the right track.
A valve on the heater hoses should work fine.
   / Shutting Off The Heat In A Cabbed Tractor #3
We had those on ambulances for years. A simple inline valve on the supply side. Turned it off in the spring, back on in the fall. Made a big difference in the patient compartment during the summer with the AC not competing with the heater core.
   / Shutting Off The Heat In A Cabbed Tractor #4
Check under the hood where the heater hose connects to the engine. Mine already has a shutoff there.
   / Shutting Off The Heat In A Cabbed Tractor #5
Whether the shutoff is in the supply or return side is immaterial. Stopping the flow is key. When the heater and A/C get fighting, the heater wins every time!
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2365 (A60432)
2365 (A60432)
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
