Shrod on PTO Shaft
/ Shrod on PTO Shaft #1
JNB
West Palm Beach, FL
2006 New Holland TC40
I tried to put the PTO shaft together on a King Kutter Rotary Cutter and did not match the two ends of the shaft correctly. I tried to bang it out and hit the little plastic/rubber clasp that holds the shroud to the shaft assembly.
Is the shroud necessary? Does the broken calsp come apart? I cant see how they got in if it does not come apart. Where do I get a repalcement to buy. Could I use a hose clamp to hold the shroud on to the shaft? Am I the only idiot who broke one of these thinghys?
/ Shrod on PTO Shaft #2
JNB:
Welcome to TBN :D! If you are describing the PTO driveline shaft cover you are not the only idiot out there; I have broken shaft-shroud connectors too :eek:. There was a recent thread about PTO shaft covers you could probably find it through the search engine. If I remember correctly you can get a replacement shaft cover through Carter and Carter Machinery, Hay Equipment Headquarters. The shaft and shroud covers are safety devices. The hose clamp idea could work, but I would tape up the excess clamp band to minimize the potential for it catching something :eek:. If you can send a picture. Jay
/ Shrod on PTO Shaft #3
TSC used to sell the covers for the KK shafts.
A shaft cover that is hard attached to the shaft securely won't doo much good if someone comes into contact with it.
That said.. it's a personal issue. I'm sure many of us have a few implements here and there with damaged or missing covers... Best bet overall is to just not approach an implement that is powered.. shaft cover or not!
soundguy
/ Shrod on PTO Shaft #4
I have always heard them called "Bippy's" for some reason. Besides safety, aren't they also used to discourage vines and talk weeds from wrapping around the drive shaft while mowing?
David from jax
/ Shrod on PTO Shaft #5
What you should see on a new shaft are 2 red screws at the knuckle ends of the shrouds. These Screws are not really screws, they are cams that hold the greenish yellow shroud to the shaft. Once its apart you should see a white plastic ring that snaps into a groove on the metal part. Make sure that part is properly seated, and not broken. The 2 Cam pieces snap into holes on either side of the white part. When you re-assemble, you'll have to play around with the screw/cams, to get them to line up with the holes in the shroud, then when it all comes together, you turn them till they cam outward, and hold the shroud in place. Shroud is important both in keeping trash from wrapping, and keeping clothing from wrapping around a spinning shaft.:eek:
2020 CATERPILLAR 249D3 SKID STEER (A62129)
2020 CATERPILLAR...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2014 Ford Escape SE SUV (A61569)
2014 Ford Escape...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
