Shrapnel in gear case
/ Shrapnel in gear case
Lots of progress, but lots of frustration also. I went from this.....
To this......
Not bad for an afternoon.
Now for the frustrating part. I went to turn the ignition on so I could turn the turn signals on to make sure that I had the harness routed correctly. I turned on the key.....nothing. I turned on the hazard lights and they work fine. So off I go testing fuses etc.
I figured that the ignition switch was safe since I had made a relay for the starter. Wrong!!!!!! Bad ignition switch. Another thing to add to the parts list. Just as soon as I get one thing on a roll......I find another. Grumble grumble..
Got home later than I wanted to from work, but was still able to get home in time to get everything back together. Started. Moved. Spun the PTO without issue with no load. Need to adjust the levers, top off the oil, torque the right rear wheel.....and she should be done.
Have a long day at work over the next two days.....but I'm thinking Saturday it'll get tested with a mower behind it.
/ Shrapnel in gear case #23
This may seem like a stupid question, but how did you git all of those knobs off?.. Just pull like he!! on them or what?
/ Shrapnel in gear case #24
Looks like you did a great job! It sure is a good feeling when it all comes back together again, despite the ignition troubles. I bet you could figure you saved a good $100 an hour vs taking it to a dealership. Way to go!
Thanks! I've been working about 75 hours a week over the past few weeks, so time has been at a premium also. It's mainly just nice to have one less thing stressing me out.
Piston, a little bit of gentle prying and some tugging and they'll make it off.
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
Bobcat T590 (A60462)
YALE FORKLIFT (A63291)
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2013 International DuraStar 4300 Ledwell 2,000 Gallon Water Truck (A61573)
2013 International...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
