Show What Tool You Made*
   / Show What Tool You Made* #391
Nice job Joel. So the blade is spinning at about 1200 rpm or so?
   / Show What Tool You Made* #392
tractorgo,
My Kubota B2920 has the option of running either 540 or 960 rpm from the rear PTO. I run the buzz saw at 960 PTO rpm, then throttle down to about 2/3 of full engine rpm. The blade is geared up by way of the pulley mounted on the gearbox, to a 2:1 factor. The gearbox is 1:1. This provides more than enough power to the saw while saving quite a bit of fuel while cutting firewood.
Joel
   / Show What Tool You Made* #393
Here's a video of my siding hammer. It's intended for vinyl siding but also good for aluminum siding. The idea is to help prevent driving nails too tightly. If the nails are driven all the way home the siding can't move and that causes buckling.
   / Show What Tool You Made* #394
This is awesome, it truly is. But being in my 40's and having spent my teens roofing houses and building houses for the Pops during the summer. It bothers me that people no longer have the skill to control your hammer. When laying shingles..3 hits..Pops would ream me if I used more than three. Three hits placed the roofing nail properly without damaging the shingle. Later that helped me when applying molding and metal work. But again..that is a time long ago
   / Show What Tool You Made* #395
The hammer is for people without a lot of hammering skill :)
   / Show What Tool You Made* #397
Video Link: http://youtu.be/OnylS2H-fBA
Nice job! Of course it would take a Canadian to come up with an idea like that :) Great idea! I'm not sure the side mounted one would work well (especially with frozen siding) but love the top mounted one. I've got 20 yrs in residential construction and that's one of the best ideas yet.
I disagree with RitchElbe. I can control my hammer as well as anyone and I wouldn't think twice about using one if I did siding regularly. Big difference between shingles and siding. Shingle gets nailed tight so the single will give you some resistance to over tightening, not so with siding as the nail has to stop before it contact the siding.
Dual sided with a top mount and flat face please. Or better yet, add side mounted claws in the middle of the head and I'd take one just to have available for the odd time I still do siding
   / Show What Tool You Made* #399
That's quite a compliment re "best idea yet"! Hoping to getting around to some more technical testing of the idea this summer to have more pitching material :)
   / Show What Tool You Made* #400
Have you improved the idea for a regular hammer buy using an flat o-ring? Or even an over mold to a standard hammer head as a slight ring on the perimeter? Thus, rather than re-invent the hammer, you can offer a slip on hammer head boot exposing 90% of the head whilest allowing the perimeter take the compression of the hit. Work on the perfecting the idea fully. Then patent the crap out of it fast. ;) The offer the idea to a tool maker as an overmold.
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
2015 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2015 CATERPILLAR...
110 GALLON FUEL TANK (A52708)
110 GALLON FUEL...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
