Show me your TnTs
/ Show me your TnTs #1
jinman
Rest in Peace
Texas - Wise County - Sunset
NHTC45D, NH LB75B, Ford Jubilee
I keep hearing that there are dealers giving people blank looks when they ask about top-n-tilt cylinders. I think we should post photos so when someone wants to get TnT for their tractor, they can just print out the photo of the setup on a tractor similar to theirs and take it to their dealer.
What do you think? Can we get a bunch of photos here? If you only have just a toplink cylinder or sidelink cylinder, post that too. This is such a great addition to my tractor, I wish it were a factory option. /forums/images/graemlins/cool.gif
Okay, I'll start with my setup on my TC45D (see attachment). The bolt holding my sidelink to the liftarm was a temporary fix until I got the hole drilled bigger (I had to buy a bit.).
/ Show me your TnTs #3
Jim said "they can just print out the photo of the setup on a tractor similar to theirs and take it to their dealer"...
Stop and think about the printed size after considering the 100k limit on uploaded photos. They might be able to copy the image file to a floppy disk and take that to the dealer for viewing on the computer there.
I thought I had some pictures of my setup, but couldn't find them.
/ Show me your TnTs #4
I just printed out Jim's pic and the resolution is more than adequate.....Not a concern.....
Now if I can only find a nice frame for that pic....I have a bare spot over the fireplace /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Show me your TnTs
</font><font color="blue" class="small">( That toplink hose looks very cracked? Or is it the photo or moisture or sumpin?
)</font>
We all wrinkle and crack a little with age... /forums/images/graemlins/crazy.gif
/forums/images/graemlins/laugh.gif
In the case of two-wire hydraulic hoses, the outside covering is purely cosmetic and has little or no value. Mine has seen over two years of Texas sun with SPF-0 sunblocker applied. /forums/images/graemlins/blush.gif
If the hose ever leaks or the wire becomes frayed, I'll get new hoses. They're too darn big for the toplink cylinder anyhow. You only need a tiny flow. I actually think that big hoses "balloon up" and allow the cylinder to move as much as 1/2 in. in and out. One of these days I'll buy a piloted checkvalve type cylinder and new hoses. ...maybe when I quit being "Mr. Cheap." /forums/images/graemlins/grin.gif
/ Show me your TnTs #6
</font><font color="blue" class="small">( ""... piloted checkvalve type cylinder.."" )</font>
Curious as to what that is and what its advantages would be?
Also, do you ever experience the tilt cylinder not holding a 3pt load on that right arm?
/ Show me your TnTs #7
)</font>
Take a look at this thread, especially the responses near the end of the thread. It should answer a lot of your questions.
Double pilot operated check valve
/ Show me your TnTs
</font><font color="blue" class="small">( Also, do you ever experience the tilt cylinder not holding a 3pt load on that right arm? )</font>
If you mean bleed-down, I have noticed a lot less on my tilt cylinder than on my toplink. I've seen none. I use my rotary cutter and don't have to readjust at all to keep it level.
If you mean weight load, that's not a problem either. The total weight felt on that lift arm, even with a load of over a ton on the 3PH, would be only half of the total weight. With 2,500 psi of hydraulic pressure and the size of that cylinder, there's nothing I'd want to lift with my tractor that the tilt cylinder won't hold.
/ Show me your TnTs #9
If the dealer gives a blank stare on top-and-tilt you could have them accesss Jim McCuan's web site Terrain Contour Control. Or have them send Jim an E-Mail at Sales@integrationengineering.net. He can explain what they are. He also offers top-and-tilt in a complete kit, valves and cylinders or valves and cylinders seperately. His cylinders have dual pilot valves and do not suffer drift or leak down like cylinders without pilot valves. I removed OEM cylinders from my L3830 and replaced them with cylinders supplied by Jim. The difference is very noticeable. No more adjusting when using to maintain "Level" or a determined setting. Very-Very-Nice. The OEM cylinders were a royal pain. The valves and cylinders were both replaced without problem correction. The installation of the cylinders with pilot valves corrected the problem. I cannot speak about leak down on tractors other than the Kubota L3830 with cylinders without pilot valves. I do know my tractor with the OEM cylinders and control valves would drift-leak down during use and when stopped.
/ Show me your TnTs #10
Thanks, and I meant 'weight' load. Glad to hear your answer.
/ Show me your TnTs #11
I don't have any good pictures, but here's one I posted in the past of my box blade tilted forward.
/ Show me your TnTs #12
And here's one with the box blade tilted back.
/ Show me your TnTs #13
Tried using the e-mail you posted Sales@integrationengineering.net
and cannot get it to work. Do you see anything not right about it? I also went to the web site, and couldn't send a message there either. Something about having to send from a web site to contact their website??
Thanks
I'd like to get more information from them.
/ Show me your TnTs
Thanks for the pictures, Bird. I was pretty sure this post would generate a lot more discussion than pictures and that looks like I was right. It doesn't matter because the more we talk about TnTs benefits and gotcha's the more we all learn about it.
I probably should have posted it in the general forums because a lot more people would see it and post. /forums/images/graemlins/frown.gif
Hindsight is 20-20... /forums/images/graemlins/blush.gif
MikePA: Relocated thread from NH forum to Attachments.
/ Show me your TnTs #16
Here is a link to a thread on TnT's and rear remotes for Kubota B series tractors. Thread contains plenty of pictures of the setup using a Prince SV valve and CCM top link, TCC tilt link and of a box scraper tilting and problems encountered.
Rear remotes + TnT for B Series Kubotas
/ Show me your TnTs #17
Good thread!
I know your header "Show me your TnTs" sure cought my eye.
-Terry
/ Show me your TnTs #18
<font color="blue">The website is www.topandtilt.com </font>
The site is good for seeing pictures, but it's woefully out of date and is a pretty good example of how not to do a web site.
Copyright still indicates 2003
No price for the TCC or associated pieces
No price for the BX High Lift Kit even though the site indicates 'Images and pricing soon. Shipping to begin February 2004.'
There's a Search feature on the site that doesn't work.
The Press Release feature has no content.
People form opinions of companies based upon their web site. /forums/images/graemlins/confused.gif
/ Show me your TnTs #19
<font color="blue"> "I know your header "Show me your TnTs" sure caught my eye." </font>
When I first read it I had flashbacks to the Indy 500 and Mardi Gras in New Orleans. /forums/images/graemlins/blush.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
/ Show me your TnTs #20
<font color="blue"> When I first read it I had flashbacks to the Indy 500 and Mardi Gras in New Orleans. </font>
/forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/cool.gif
Those were the days... /forums/images/graemlins/laugh.gif
2013 CHEVROLET SILVERADO 2500HD (A63569)
2013 CHEVROLET...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Arrow Quip 8800LV Cattle Chute with Sternum Bar and Head Holder (A64047)
Arrow Quip 8800LV...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
