Shoulder Replacement Surgery
   / Shoulder Replacement Surgery #21
Scotty:
If that is titanium it is worth some money :D! I still have 6 screws, two pins, a plate, and some wire in my ankle, staples in my lung, and shoulder. When it is time to "bake and shake me" my will will request that I go to a smelter; I will be worth some $ :). Jay
   / Shoulder Replacement Surgery #22
Red - if you're in that much pain and the doc says it's a necessity, definitely don't put it off. The longer you wait, the harder it is to recover. Just be sure that, if you smoke, STOP SMOKING and give your body a few months to adjust to the lack of nicotine before the surgery. If you smoke, you lengthen your recovery time by a lot - nicotine really screws up your body's ability to flow oxygenated blood effectively, and that makes for a long recovery. Also, if you can, do some mild cardio exercise during the weeks before the surgery.
I've seen shoulder replacements go really smooth when people are healthy and they do all their physical therapy. I've also had a few friends and family members have an awful time when they didn't take care of themselves before and after the surgery. The good thing about surgery like this is you can play a very big part in how well you do - you just have to train for it like a major competition.
I hope it goes well for you!
   / Shoulder Replacement Surgery #23
I agree with mahlers. If you do not take care of your body your body will take care of you, and the results are usually and ultimately unpleasant :eek:. I am slowly starting to learn this lesson :eek:.
Red- Please take care of yourself. Jay
Well, I went for an MRI on Thursday, which was an ordeal in itself. I'm too big to go in their tube, so they used what they call an "open MRI". I had back surgery about 20 months ago, so I knew what to expect. I'm semi-claustrophobic, but I had no problem when I had the MRI before the back surgery. The problem this time was that they adjusted my shoulder in some kind of contraption to keep it in the proper position, and it put my shoulder in a very uncomfortable position. I figured I could stand it, but as the time went on, it became extremely uncomfortable. I mean EXTREMELY uncomfortable. If you've had an MRI you know that they tell you to remain as motionless as possible. Well, since the fusion surgery I had in 2006, it is difficult for me to do that. Do you remember when your coach was running you to find out who really wanted to play? I had to use the same kind of mental discipline to keep myself from pushing the "panic button" the technician had given me as I did to keep running those wind sprints forty-two or forty-three years ago. By the time I got out of the thing, I could hardly get off the table.
If they told me I had to do it again, I would say, "fine, just you give me a couple of those 'happy pills' y'all keep around here."
I took the films to the doc on Friday. He studied them himself and read the technician's analysis. He said my rotator cuff, while not torn completely through, was torn very badly. He said a combination of the damage to the rotator cuff and arthritic degeneration of the socket part of my shoulder joint made him afraid that conventional joint-replacement might result in the socket (I forget the exact technical term) fracturing. He said he thought I was a candidate for something called "reverse shoulder replacement".
I said, in my best country hick voice, "Say what?"
He explained that it meant that they attach a new ball joint to the top bone (scapula, maybe?), and a new socket to the lower (humerus) bone. That's just the opposite way from how God did it in the first place. He said that he doesn't do that operation, and that he was sure I wouldn't want him learning how on me, but that there is another doc in the hospital who does do it. I have an appointment with this doctor Wednesday morning.
http://www.hughstonhospital.com/CustomPage.asp?guidCustomContentID={9574F6C3-9B7E-41B6-B0FE-A723C926431D}
At the bottom of the linked page are x-rays showing a before-and-after of someone with this type of surgery. The doc I'm going to see wrote the article, and the Hughston Orthopedic Hospital has been in business for a long time. They took good care of me when I had my back surgery, so at least I have confidence in the doctors.
   / Shoulder Replacement Surgery #25
Red
So when's the big day?
Will there be a chance you'll be ready for a casting call....because we are just finishing up the script for "The NEW 6 Million Dollar Man"...and we think you have the backround to pull it off...:D
   / Shoulder Replacement Surgery #26
redlevel:
At least you were spared the "inconvenience" of a double run in the MRI machine :eek:. It amazes me how they can "fit" you in those MRI position keeping contraptions
:(. Good Luck- Jay
   / Shoulder Replacement Surgery #27
I was searching for a "shoulder" thread and came across this. Now I need to know how the surgery came out. I hope ok.
Anyone else have shoulder problems?
   / Shoulder Replacement Surgery #28
No replacement, just rotator repair. I put it off until I could not reach the radio in my pickup. What was expected to take about two hours went to six because my bones were so soft the surgeon ended up having to insert some kind of teflon bolts.
I firmly believe that if not for my physical therapist that I would never have been able to raise my arm above shoulder level again. This man had spent his Army time at Walter Reed working with vets mostly with injurys sustained in the middle east. I did put the effort in as I did when I had meniscus and PCL surgury on one of my knees but this guy could "read" my movement and knew where to push me, etc. I have an occasional day when I notice my shoulder but that reminds me not to push it to hard. Maybe just put a hundred bales of hay up in the loft and save the next one hundred for tomorrow, lol!
My wife has been getting the rooster comb shots in her knees and now they took some of her blood, treated it and put some back. Her knees are a bit stiff but she does not have the pain as before and cortizone would not help any longer. I don't know if this kind of therapy is done on shoulders? We go back on November ninth. I will have to ask.
She has heart issues, high BP, leaky and malformed valves, irregular beat along with a miriad of other maladies so she wants to avoid knee replacement as long as possible.
   / Shoulder Replacement Surgery #29
I've had 2 shoulder surgeries on my right side. First one the surgery went well and rehab was ****. Second one they relocated my biceps tendon from my shoulder to my arm. The surgery and recovery for about a week was awful, but after that and weeks of not being able to do anything with my arm.....rehab went great! Pretty much pain free now, but a lot of hard work can get it sore on occasion. Installing helicopter rotor blades can get it sore for sure! Anyway, my lessen from all this was that if it's keeping you at night it's time to get it fixed!
   / Shoulder Replacement Surgery #30
they installed the weather package chip in the knee durring repair ! :) I can tell a full day in advance that its going to snow before the weatherman even knows ! :( Hopefully they dont still offer that option ! ;)
The docs have been installing that weather chip since 1958 when I broke my left knee. My left knee tells me when it is going to rain and the right one tells me when it is going to snow. The more painful it is the more we are going to get.
   / Shoulder Replacement Surgery #31
I had been prescribed an antibiotic about 3 years ago. I started noticing pain in my left shoulder when I only had 1 or 2 days left of pills. I did not know at the time that some types of antibiotics would cause shoulder tendon damage. Anyway, the left shoulder got better after about a year of just nursing it. Fast forward and 16 months ago I had to take another round of antibiotics and this time it messed up my right shoulder. I have nursed it since then. I can use it in most directions, but there is 1 certain type of movement that is crazy painful. This makes me think the damage is mostly in 1 or 2 tendons. I'm hoping that just nursing it will cure it since the left shoulder is fine now.
   / Shoulder Replacement Surgery #32
Kyle, do you remember the type of antibiotics?
I've had pain in both shoulders for over a year..not usually too bad, but when I reach behind me to pick up something it can really hurt. This year I feel it has made pulling my bow more difficult. So I plan to discuss on my next annual physical visit with my doctor.
   / Shoulder Replacement Surgery #33
Unfortunately I can't remember the name. But I'm pretty sure it was kin to the Cipro family, but not Cipro itself.
   / Shoulder Replacement Surgery #34
My sister has had both shoulders replaced. About 1 1/2 years apart. First one was a longer recovery. I guess they constantly improve the techniques as the second one was much quicker recovery. She is great and range of motion restored. She recommends it if you are restricted or in great pain currently. BTW we call her the bionic woman as she has also had both knees and hips replaced as well !
paul
   / Shoulder Replacement Surgery #35
I had a full knee replacement July 6 and still recovering . Some people recover very quickly , I wasn't one of them . I have been sleeping in a recliner up until a few days ago and had to go back to the recliner last night . The surgeon said," it could take up to a year before things could calm down ". PT hasn't been to bad , and I can walk along pretty good now . Although this has been a very long process for me I am still glad I had it done as I have friends who opted not too , and they are suffering much more than me . On some days before surgery I would have to use crutches to get around, that is not the case now . If it be a shoulder or whatever if it is altering ones lifestyle it may be time to make the decision.
   / Shoulder Replacement Surgery #36
My father-in-law had both his shoulders replaced. The right one last August and the left in March. He had been going to a doctor that told him there was nothing left in the shoulder to attach replacement parts to. Wish I could post his X-rays and you would see what he was talking about. The rotator cuff on the right side was totally missing. The ball in the ball-and-socket joint rested above the socket. The doctor said the ball looked like a piece of lava rock. To feed himself he would grasp his right arm with his left hand. He would hold it slightly below the elbow and by leaning forward he could get the fork into his mouth. He was in constant pain and I was afraid of what he would do to relieve himself of his pain. He was 87 years old when we took him to another doctor. I had been to this doctor with my knee and one of the first things he told me was that unless it was an extreme case he would never tell a patient that a joint needed replaced. I would have to tell him my knee was hurting so bad that I wanted him to replace it. When he walked into the office he looked at my FIL's x-rays, turned to him and said, "we have to replace this as soon as possible". His assistant said it was the worst he had ever seen on a non accident victim.
Anyway they did what is called a reverse replacement. Instead of the ball being on the arm and the socket on the shoulder their positions were reversed. Also the deltoid muscles were reattached to lift the arm since the rotator cuff was gone. It took about two months each to recover from the surgeries. FIL has mowed his yard all summer. He uses his weedeater. Only problem is that he cannot raise either arm higher than straight out horizontal. He is not in any pain.
In a knee replacement this doctor pusher PT and encourages people to go beyond what the therapists do. For this surgery he warned my FIL to not go to extremes and when FIL told him the therapists tried to get his arm higher than horizontal he told him to quit therapy.
Once again last summer he could barely feed himself and now he mows his yard on a zero turn, uses a weedeater, and has recently traded cars. He will be 89 on January 20th.
One note of caution. If a doctor is advertising on TV they cannot get enough patients by word of mouth and I would not go to them. There are a couple in our area, one in particular, and I know of no one who has been happy with their work.
It takes about four months to get an appointment with this particular doctor. Then you usually see his assistant who is very competent.
As for myself I had a bone spur inside my right shoulder joint. Had it removed and have no problems. I have to sit and think to remember which shoulder it was. BUT, after the surgery the doctor said it was supposed to be the single most painful surgery you can have. For about four days it is incredible painful. Had to stay knocked out or would lay there and cry. Talked to one guy who had heart bypass, hemorrhoid, hernia, and a couple other surgeries and he said he would have them all again before he would get a spur removed from inside the shoulder joint.
RSKY
   / Shoulder Replacement Surgery #37
Hang in there and give it time. Sept. '14, I had both knees replaced at the same time and when I went back for my 6 month visit, I let them know how unhappy I was that I still had pain that woke me up several times a night. They told me that it could take up to a year to heal, but at 7 months, I started sleeping at night and just kept getting better. I am pain free and do anything I want and can walk without pain. Like you, I'm really glad I had it done both at once.
   / Shoulder Replacement Surgery #38
I had the full right knee replacement done 8/30/2010. And now my right shoulder has been giving me lots of trouble and pain for a few years. So I finally went to the orthopedic shoulder specialist this morning; lots of x-rays, 2 shots of cortisone, and scheduled for an MRI tomorrow. But in showing me the x-rays, bone spurs, lack of cushion in the joint, etc., I think he's pretty well convinced that I'll soon need the right shoulder replaced. Needless to say, I am not looking forward to that. I guess I'm soon going to be made of spare parts.
   / Shoulder Replacement Surgery #39
Five years ago or thereabouts I ripped out two tendons in my left shoulder.. The arm just hung there with no ability to lift it away from side. I had some strength curling but not much. They went in and spent 6 plus hours inside there putting it all back together. I have full range of motion and strength with that arm.
They want to remove the bone spurs in right shoulder but I'm putting that off as long as possible.
The pain wasn't an issue with me. By day two I was off of the pain killers and relying totally on the ice machine. If you do get the surgery and want to borrow the ice machine that is not an issue. Insurance doesn't cover it but it is the only way to recover in my book. By day four I was still in the recliner but could detach from the ice machine by myself and was basically independent. I went to Haiti with only two rehab treatments. Five weeks later I was back home and it was just a couple of weeks of rehab when the therapist told me to go bother someone else. The important thing is the full effort at rehab. Most of the people I know who have had shoulder surgery slacked off and now have a limited use of the arm.
If you get the surgery and want to use the ice machine give me a call, you got my number.
The last photo not only shows the ice machine pad but youngest granddaughter photobombing. If you look at the photo you will see the quick connect fitting, one of them. Ice water is pumped around the surgery and it's better than syrup on pancakes.
   / Shoulder Replacement Surgery #40
Sorry to hear that Bird. Lots of rehab coming your way. Hope it goes well. Hips are easy, knees not too bad but shoulders are the biggest challenge for rehab. Hope you have a cute physical terrorist to work with as you recover.
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2024 MECO M-Y 4-Passenger Electric Car (A59231)
2024 MECO M-Y...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
Schulte XH1500 Series 4 15ft Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
2019 CAT 259D (A60462)
