Should my PTO do this?
/ Should my PTO do this? #1
slofr8
Northern Maine
Mahindra 4035
Hi all,
I've been using my new (to me) L305DT and it seems to be just what I needed. I decided to spoil myself and ordered a new rotery cutter, and box scraper. They should be here in a week or so. I had not tried the PTO other then to make sure it turned when I bought it. It has a 2 speed PTO. Well tonight I noticed that it didn't stop turning when I pushed the clutch all the way. It would even speed up when I raced the engine with the clutch disengaged. I only hope that it doesn't need a new clutch, but what else could it be? Can I mow with it this way? I adjusted the clutch as per the manual and it works well for shifting but this has me worried.
Thanks for any insight. Dan.
/ Should my PTO do this? #2
That is the way the PTO on my L4630GSTC operates also. You engage the PTO and it is on. My New Holland stops when the clutch is disengages. Different type of PTO.
/ Should my PTO do this? #3
If the PTO does not stop turning when you push the clutch, the rotary mower will push the tractor forward whenever you engage the clutch. My 1948 Ford 8N was like that. I thought all modern tractors had been improved since then. You need to mount an external over riding clutch to the PTO shaft it will cost about $60 at any decent tractor supply.
/ Should my PTO do this? #4
Does the 305 have a two stage clutch? We don't have any of them around here that I've driven to know but often when working with older tractors they don't have enough resistance to stop the shaft as they were not equipped with a brake on the pto like they are today.
/ Should my PTO do this? #5
I would call the dealer and see what they recommend. Sounds like your clutch needs an adjustment. I know on my L2800 with a manual tranny, When I depress the clutch all the way, within a few seconds, my finish mower blades stop turning. I am then able to shift into reverse and back mow in tight spaces and the blades will start turning again when I let off the clutch slighlty. Sorry that I'm not much help but I would call the dealer.
/ Should my PTO do this? #6
Sorry to reply again, but I just thought of something. If you are turning your PTO on without an implement attatched to it, then yes it will continue to free spin for a while. When you hook up your rotary cutter, the slight resistance from the implement will cause the PTO to stop spinning when you depress the clutch.
/ Should my PTO do this? #7
Marc... ya might need to do a little more research...... My ford 5000 and NH 7610s pto keep sturing when i push in my clutch.. WHY? Because they have an independent pto.
A ford 8n has a single stage clutch and non live pto.
Independent pto is defacto live.. even if it is a pingion hand clutch style.
The other way to get a live pto is with a 2 stage clutch.
If this kubota has an independent PTO. the main clutch may not effect it.
Independent pto and a 2 stage clutch pto don't have the drivetrain backfeeding problems that the single stage clutches do.
Last option is possibly that he is getting fluid coupling on the pto when it is disengaged.. and the pto break is inoperative.. or it doesn't have one.
Soundguy
Thanks for the replies.
It doesn't spin unless it's engaged but wont stop with the clutch pressed. The manual states..."both transmition and PTO clutch are disengaged when the pedal is fully pressed down." I'm hoping it's what Bama85 said,
"If you are turning your PTO on without an implement atatched to it, then yes it will continue to free spin for a while.", however, I can hold the clutch in for ever and it never seems to stop on its own. I'll know more once I get the mower but I was just wondering if this was something common or if it was easy to troubleshoot.
Thanks again. Dan.
/ Should my PTO do this? #9
Tractor Data lists the L305 as having a live pto - so I think it has the same style 2-plate, 2-stage clutch as the L345 (which I had). Is there a hinged swing stop for the clutch pedal? If so, its purpose is to stop the pedal for 1st clutch disengagement, and swing up to allow full pedal motion to disengage the second (pto) clutch.
There is a possibility the pto clutch is just stuck from lack of use - so you should test it with the rotary mower to be sure. But with a 2-stage clutch the 1st clutch gets worn over the years and the linkage has to be adjusted to compensate. Unfortunately if adjusted too far, the linkage stops releasing the pto clutch. The adjustment can be balanced so both work for a while. Some tractors have separate adjustments but these don't. The real answer for my tractor was a new travel clutch.
I ran my L345 like that (pto clutch engaged) for a couple seasons - after initial warmup I'd shut off and restart the tractor with the pto lever in gear. I'd slip into neutral so spinning implements could coast down. I finally just split the tractor and put in a clutch - not that big a deal.
Rbargeron,
Yes, it should have the hinged stop plate to limit the clutch travel when the PTO isn't in use but it's missing. Also, when I adjusted the clutch I noticed that part of it had broken at some point and the rod was welded to the shaft leaving the trany. This means that the clutch has only one point at which it can be adjusted rather than two. I was able to get it adjusted to where it shifts good and pedal travel is to spec but this may also be a contributing factor.
Hopefully it clears itself up when I start using it, but I'm not holding my breath. Worst case I'll split the tractor after I get my "must do" list done.
Thanks and Happy 4th. Dan.
/ Should my PTO do this? #11
Dan - changing the clutch requires an alignment shaft that centers the clutch disks when bolting on the pressure plate. I have one for the L345 - according to this eBay listing the clutch assembly is the same for L305 and L345. This listing includes the pressure plate and pto clutch which you likely do not have to replace, provided you get to it before the travel clutch is down to the rivets. I'd get the travel clutch (13-spline) and a release bearing only. (should be under $200) I'll lend you the alignment tool when (if) you need it, PM me with an address. Take care, Dick B
/ Should my PTO do this? #12
If it is a 2 stage clutch, the 2nd stage may not be releasing, it might be misadjusted.. or just sticky..
Once you put a load on it you will know more.
Soundguy
Thanks again. Dan.
Well, my mower and box scraper came yesterday. Hooked up to the box and moved a whole lot of ground for better drainage around the house. Also fixed up some road that had started to wash. VERY sweet rig. The L305 does a great job with it.
Then I tried the mower. Mower runs good but the only way I can get the PTO to engage with the mower on it is with the tractor not running. Not real convenient. I'll use it the best I can for a while and then dig into it.
Rbargeron. I'm blown away by your offer to lend me that alignment tool and I'll likely take you up on it. I've got a solid month or two before I can tackle anything like this. Loader will have to come of and I really don't know what to expect once I get in there but I'll give it a try since the nearest dealer is 60 miles away. Either way I let you know what I do.
Thanks, Dan.
Update. My manual makes no mention of it but there are two covers on the side of the housing. One allows you to grease the release bearing and the other allows you to adjust the clutch. I just backed off the three adjustment bolts two and a half turns and LOOK OUT!! PTO stops when I push the clutch all the way!! I was getting ready to split the thing in a month or two. I even bought two heavy duty wheels to be able to do the split once the tractor is separated.
I realize there is clutch wear or I would not have had to adjust it, but I think I can go quite a while before I have to worry about it. Now that I see how it all works I not so intimidated to tackle the clutch if and when I have to.
It's just like X-mass here today!!!
Thanks. Dan.
2011 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2011 INTERNATIONAL...
1986 Value 96"x40' Drop Deck (A64912)
1986 Value 96"x40'...
2006 KENWORTH W900 (A67714)
2006 KENWORTH W900...
PALLET OF MISC MOTORS AND PARTS (A68842)
PALLET OF MISC...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2014 International WorkStar 7500 T/A Leach 2RIII 25Yd Rear Loader Garbage Truck (A66736)
2014 International...
