should I worry about this thorny problem?
   / should I worry about this thorny problem? #1
2manyrocks
Super Member
I'd like to clear an area that has about 15 honey locust trees with 11" long thorns all over them. Ordinarily, I'd chainsaw the trees into manageable sections and move them with my tractor grapple, but I'm not going to operate my tractor in this area with these thorns.
My first thought is to rent one of the rubber tracked mini skid loaders like a Vermeer with a small grapple, but I'm wondering if these thorns will damage the tracks which I understand to be very expensive to replace?
Another question I have is whether I could run a hydraulic winch off the Vermeer hydraulics to pull some of the tree trunks off into the woods to leave to rot. I have some areas where I could drag trees with a cable, but I would not want to run a loader because of the terrain. However, I could set a winch cable and pull the trunks where I'd like them to end up if I had the appropriate winch system.
I don't know of a winch that could be rented for one of these loaders. I was thinking perhaps I could fabricate an attachment to go on the front of the loader and then connect something like this to the loader's hydraulic system?
   / should I worry about this thorny problem? #2
Use an excavator. Take root and all. Pile them in the same area that they are currently in so you don't spread those thorns. Burn them soon as they dry out enough.
Been cutting/burning them for years. I have hundreds if not thousands of those thorns in my tractor tires.
   / should I worry about this thorny problem? #3
I have never seen 11" long thorns on a Locust tree. Please post a pic of these amazing thorns.
   / should I worry about this thorny problem? #4
And I thought the thorns on my two Russian Olives were bad...........
   / should I worry about this thorny problem? #5
While the individual thorns aren't 11", I'd say this one is close enough...
How'd you like that in your keister? 😬
   / should I worry about this thorny problem? #6
Is that from a Locust? I have locust in NC and thorns might get 2-3" long.
What kind of diabolical plant makes that thorn?
   / should I worry about this thorny problem? #8
   / should I worry about this thorny problem? #9
Must be all that nuclear waste someone's dumping in Indiana to make thorns like that.
If anything like what you have in your hand showed up on my property, I would get out the flame thrower and burn it in place after calling the fire dept.
   / should I worry about this thorny problem? #10
That's not my hand. It's just one of many you can find with a google search.
I have black locust on my property. About 10-20 thousand in just a 10 acre swath. Very small thorns on the smaller branches.
Honey locust is thorny on the trunks. You wouldn't want to fall on one. I've heard references to 20+ inch thorns.
1660 (A59213)
1660 (A59213)
New/Unused Spirit Electric Tricycle (A57453)
New/Unused Spirit...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59575)
2018 INTERNATIONAL...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Cameras and Video Camera (A56860)
Cameras and Video...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
