Should I swap my airchucks from general ones to auto ones?
   / Should I swap my airchucks from general ones to auto ones? #31
If the tool requires air volume that is at, or near the limit of what you are supplying it, like a decent sized air grinder, perhaps you could see a difference.
Most tools, that use 1/4" fittings, don't draw a lot of volume, so it won't matter.
If you are concerned about that restriction, eliminate the fitting. Connect the hose directly to the supply line. I would install a ball valve before the hose, so you can turn it off when you have a failure.
My Nitto Koiki angle grinder uses 20 CFM. (.9 HP). I've used the same style 3/8 hi flow automotive couplers in my shop for almost 40 years.
Good plan on installing ball valves. I use ones with an exhaust port. Makes attaching / re-attaching easier.
Terry
   / Should I swap my airchucks from general ones to auto ones? #32
My Dewalt air impact came the fitting stile on the right as some other tools I have did, seems like it has plenty of power. All my air jingle jangles plugs into this> 3/8 in. x 5 ft. Retractable Hose Reel
My biggest complaint is the constant changing air chuck plug-ins to stop the the constant air plug-in leaking, every couple months I have to change the air plug-ins, why? is there a good brand, better than the HD ones, what are those stile air fittings on the right called? non auto motive......
Your problem MIGHT be moisture and corrosion in your system preventing proper seating in the coupler.
   / Should I swap my airchucks from general ones to auto ones? #33
Terry
That's the problem with true high volume fittings. You have to discharge the line to connect them. Not very convenient, if you change tools a lot.
There is another option, many are not aware of: RBL Products 610 M-Style 1/4" Coupler Set w/ Female Coupler / Plug
These are higher flow than standard "m" style.
This coupler works with their higher flow plugs, and is also compatible with standard "M" style plugs.
A bonus is, you do not have to retract anything to couple them, just plug it in.
   / Should I swap my airchucks from general ones to auto ones? #34
If it is or isn't, I do have alot of moisture in my line all the time and it's a vertical tank didn't think water would be that big of a problem, I have to look for something for a water remover.
   / Should I swap my airchucks from general ones to auto ones? #35
A that's not quite true, I'm not sure what type we have at work but the air hoses are about 3/4"o.d., 1/2" or so i.d. The air chucks are bigger than what I have, and we change tools all the time, plug unplug, the air chucks have some sort of thing to keep air from coming out, the hoses never loose air when changing tools, and they are HIGH volume air chucks for HIGH volume air tools, no HF air tools there.
   / Should I swap my airchucks from general ones to auto ones? #36
Thanks for the link. I'll look into those couplers.
I don't HAVE to exhaust air pressure between the wall outlet and tool to reconnect. Sometimes if I leave something hooked up but not in use (such as the air shear or paint shaker) I like to relieve pressure on the lines and cylinders. But that's just me
Terry
   / Should I swap my airchucks from general ones to auto ones? #37
I don't know what you are using either.
None of our vendors, or customers had 3/8 couplers you could connect without blowing the line down.
The only other option we had, and some customers used them, was a Dixon, or Chicago fitting, which is full flow. And, you defiantly are not coupling those with the air on.
   / Should I swap my airchucks from general ones to auto ones? #38
Terry
It doesn't look like you use that shear, could you crate it up and send it to me? :thumbsup:
   / Should I swap my airchucks from general ones to auto ones? #39
LOL. I picked it up cheap earlier this year. The sheet metal shop that had it converted it to air.
I had to re-tweak the geometry, rebuild some linkage, replumb the air and add safety guarding. New paint does wonders...
Terry
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Pace American MW8516TA2 T/A Enclosed Concession Trailer (A56857)
Pace American...
John Deere Gator (A53317)
John Deere Gator...
13 Ft Ball hitch Trailer (A56859)
13 Ft Ball hitch...
DEWALT CHOP SAW (A58374)
DEWALT CHOP SAW...
CAST IRON POT (A58374)
