Should I repaint my JD 2210?
   / Should I repaint my JD 2210? #51
What is a good black paint to use for touching up the metal pieces? Can I get something at Ace that is good enough?
I use the JD gloss spray paint sometimes, its about $6.99 a can.
And i also use krylon gloss paint.
Thanks- Sounds like I need to drive out to the JD shop soon then.
I started tearing down the tractor tonight- Pulled the front and side pieces, then took the loader and the loader mounting bracket off. Pulled the plastic kick piece off and instrument cluster and got stalled when I could not get the steering wheel off. I need to pick up a three-arm gear puller to continue there.
I took my booty to the wash sink and gave it a good bath, then used a citrus based solvent on the parts with overspray on them. It came off pretty well. I may be able to just wax up the side pieces and use them without re-painting.
I pulled the battery out and had a little rust under there, and a lot of dust. Dust way up in the electrical connectors under the gauges too.
I took a chisel and scraped off the concrete splatter too. I'll need to sand and paint the bucket and hood for sure, but maybe I can just clean up the other pieces.
After I got the loader off and battery out (disabling my snow-removal tractor), I realized I had parked it in front of my blade for the Jeep (my only other way to move snow from a 1/4mi drive, other than a shovel). That was guaranteed to make it snow tonight, and it has a little already so far, after nothing for almost a month. :)
I got my gauge put together, and attached it to the loader-down port and fired up the engine. The pressure goes from zero to 1500psi in about a 1/2 second, then takes another 4 seconds to creep up to a peak of 2200psi
I tried it at idle, and mid throttle, with about the same results.
Does that sound normal?
   / Should I repaint my JD 2210? #54
I do not remember what the max number is for the 2210, but that sounds close.
I've been making good progress- I started by scraping off the concrete splatter with a dulled wood chisel. Then used Goof Off to remove the over spray (still need to finish the loader arms).
I pulled the front grill, used a tooth-pick to clean out the concrete and sprayed a light coat of paint on it. It is amazing how much better it made it look.
A little touch-up paint where needed, and a coat of buffing compound, then cleaner/wax and it is good to go.
I also cleaned up the battery area some- was just too much of a mess and I didn't want it rusting out on me. I ordered fittings to replace the cables, but will have to do that the next time I'm in there.
I cleaned it up with a wire brush and air hose, then used the best paint-over-rust primer I could find. Dried it with a pair of 250W halogen lamps on it, then sprayed three light coats of the paint-over-rust paint.
Before:
After:
Here are some more pictures that I'll let speak for themselves-
This is the temporary spray boot I made up- Worked pretty well for keeping the fumes out the house, but not perfect. I would open a window across the room and use the fan to pull out the over-spray/fumes. But when it was cold out, it cooled down the room pretty fast. I ended up hanging two halogen lights above the spray area- the thermal heat from them kept the parts warm and baked on the finish.
   / Should I repaint my JD 2210? #58
Looking good!
Keep posting pictures.
Yep- lots of fun. Every time I drive on the road now I want to go get the tractor and fix some bump or hole. Of course it's a mud pit right now, so I've got to wait a little.
Here are some photos I put on another thread:
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
UNUSED FUTURE 32" HYD MINI TILTING BUCKET (A57193)
UNUSED FUTURE 32"...
1827 (A51248)
1827 (A51248)
2010 Chevrolet Equinox SUV (A55853)
2010 Chevrolet...
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54757)
(APPROX 32) 6' X...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
