JohnDeere4300
Veteran Member
What is a good black paint to use for touching up the metal pieces? Can I get something at Ace that is good enough?
I use the JD gloss spray paint sometimes, its about $6.99 a can.
And i also use krylon gloss paint.
I got my gauge put together, and attached it to the loader-down port and fired up the engine. The pressure goes from zero to 1500psi in about a 1/2 second, then takes another 4 seconds to creep up to a peak of 2200psi
I tried it at idle, and mid throttle, with about the same results.
Does that sound normal?
