Should I leave them Loaded?
   / Should I leave them Loaded? #11
Shane, I'm only about 20 miles from you (as the crow flies) and on very similar terrain/soil. I have a Mahindra 6500 with R-1's and all four tires loaded. Now our house in on the crest of a hill so it drains well and our lawn is "farmhouse" lawn, not putting green. BUT, I run the tractor on the lawn a lot (not mowing, but fixing fences, carting materials, etc.). In the past year plus there have only been maybe four days that I would have damaged the lawn and resorted to the Gator to avoid it. Our rocky clay soil (if it drains at all) hardens up really quickly. Since you haven't damaged anything thus far -- leave 'em loaded. Just be prepared to put off mowing for a few days if/when we ever get a lot of rain.
   / Should I leave them Loaded? #12
Scrounger said:
Personally, I dont like the loaded tires. I have a BX and when I mow I want the BX as light as possible. When I use the FEL, I put the BH on and I have no issues. In the winter with the FEL and RB on, I still never needed the extra weight or chains.
It all depends on your lawn, but overall, I would think your lawn would be happier without the loaded tires.
No filled tires on my BX 23 either.
   / Should I leave them Loaded? #13
Your profile list's a loader, bucket and pallet forks on that tractor.
DO NOT REMOVE FLUID!
You'll be taking it back to the dealer to have fluid put back in shortly after removing.
Well fellars, I guess I'll leave em loaded. Especially since it's so dry I won't be mowing :(.
If (just a wondering if) I wanted them unloaded what would be the ramifications of all that unwanted, unrequested moisture left behind in the tires? Would it possibly cause some kind of premature rusting of the rims?
   / Should I leave them Loaded? #15
If they filled the tires with liquid that will cause rust (plain water), then they'll rust regardless of whether you keep 'em filled or not. If it was something that won't cause rust, a little left inside won't cause a problem.
From the perspective of taking care of grass, if you want healthy turf you don't want to put any more weight than you have to on it. Even if you aren't digging ruts in the ground you're compacting the soil, which prevents good root growth.
On the other hand, if you're mowing with a big tractor you're putting quite a bit of weight on the grass anyway...
   / Should I leave them Loaded? #16
If your rears are filled with a CaCl solution it is pretty corrosive stuff. I would leave your tires filled. Jay
   / Should I leave them Loaded? #17
Any ruts in the lawn now? No?
Then leave them loaded.
   / Should I leave them Loaded? #18
If you don't want them loaded start a post looking for someone with a similar tractor who uses it for serious FEL work, or lives in hilly country, or uses it to pull logs etc and would like to swap their MT tires for your loaded one. He will gladdly make a deal.... :)
   / Should I leave them Loaded? #19
Wish my dealer was as good as yours!
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
2019 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
John Deere 2700 Mulch Ripper (A50514)
John Deere 2700...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A50322)
2025 Single...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
Electric Wheel Hyd. Dump Wagon (A50515)
Electric Wheel...
