Should I install, at least, a temp gauge?
   / Should I install, at least, a temp gauge? #11
The temperature gauge on my Yanmar powered JD failed so I added generic gauges. I became concerned because it was never getting over 160F. Come to find out my Yanmar engine has a 160F thermostat and that is the only part number Deere lists for it.
   / Should I install, at least, a temp gauge? #12
Relatively speaking adding gauges is a low cost addition if it provides you greater comfort in operating your new to you tractor.
A caution is that it is 40 years Japanese tech. Warning lights were common for that we are more use to seeing gauges for today. But realize that most gauges are not mechanical gauges that are on the market.
I have even considered adding 2 gauges to mine (oil pressure and voltage).
You may want to search YM2610D gauge cluster completed thread for a nice looking gauge upgrade.
   / Should I install, at least, a temp gauge? #14
A working temperature gauge is important on a tractor because they’re prone to getting the radiator plugged with chaff and overheating. The first thing I would do is check the accuracy of the current gauge with an IR thermometer.
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
COSMO SPIN SPREADER, 3PT (A52708)
COSMO SPIN...
tractor disc harrow 84in attachment (A56857)
tractor disc...
VINTAGE EVINRUDE MOTOR (A58374)
VINTAGE EVINRUDE...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
