Should I install, at least, a temp gauge?
   / Should I install, at least, a temp gauge? #11
The temperature gauge on my Yanmar powered JD failed so I added generic gauges. I became concerned because it was never getting over 160F. Come to find out my Yanmar engine has a 160F thermostat and that is the only part number Deere lists for it.
   / Should I install, at least, a temp gauge? #12
Relatively speaking adding gauges is a low cost addition if it provides you greater comfort in operating your new to you tractor.
A caution is that it is 40 years Japanese tech. Warning lights were common for that we are more use to seeing gauges for today. But realize that most gauges are not mechanical gauges that are on the market.
I have even considered adding 2 gauges to mine (oil pressure and voltage).
You may want to search YM2610D gauge cluster completed thread for a nice looking gauge upgrade.
   / Should I install, at least, a temp gauge? #14
A working temperature gauge is important on a tractor because they’re prone to getting the radiator plugged with chaff and overheating. The first thing I would do is check the accuracy of the current gauge with an IR thermometer.
2000 INTERNATIONAL 4700 (A58214)
2000 INTERNATIONAL...
Forklift Telescopic Boom W/11ft Extension (New/Unused) (A59225)
Forklift...
(2) AIR OVER HYD JACKS (A58374)
(2) AIR OVER HYD...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
3PT SCRAPE BLADE (A58374)
3PT SCRAPE BLADE...
