Should I change to a two stage pump?
   / Should I change to a two stage pump? #11
5" cylinder with 16 gpm should be in the neighborhood of 14-15 second cycle time.
Well then, it seems I will be going with the 16 gpm pump. I will post some pics (hopefully in the next couple of weeks) of the finished product.
Thanks for all of your input
Hey one last question on this general topic. I am building this as I said using a horizontal drive motor. I have seen descriptions of the pumps that would lead me to believe that some of them can only be used in a horizontal configuration????
I have a spare 8hp vertical shaft motor off of an old riding lawn mower that I was thinking about fabbing up another log splitter with someday. Do I need to look for a special pump or is the shaft simply the wrong size? Do the bolts not line up? (or do certain pumps only work in certain orientations?)
Educate me!
Thanks again
   / Should I change to a two stage pump? #14
I can't say for sure about the orientation, but here is the .pdf for the Haldex-Barnes 2-stage pumps. I didn't read it word for word, but I didn't see anything in there that mandated horizontal-only orientation. A quick call to their engineering department should clarify.
As for coupling the pump to the engine, I think the best way to go is to use a "lovejoy coupling". The shaft of your pump will likely be 5/8" keyed, and I would imagine your engine crankshaft is 1" keyed or larger. The Lovejoy coupler makes it easy. The "L" type is the one most commonly used. Just get a 5/8 half for the pump, and a 1" (or whatever the proper size of your crankshaft) for the engine, and the spider, and you're good to go.
   / Should I change to a two stage pump? #15
Here's a link to a handy calculator for cylinder speed at a given GPM rate.
cycalc.xls
There are also other handy calculators on that page and a few more here. Look down along the left side of the page.
SURPLUS CENTER TECHNICAL HELP
Thanks guys - great info
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
Mini Margaritaville Truck (A55853)
Mini...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
SKID STEER ATTACHMENT (A58214)
SKID STEER...
