Rotary Cutter Should blades swing freely?
/ Should blades swing freely? #1
tstellanova
Hilo, Hawaii
I've got a Frontier RC2048 (two blades).
It's been vibrating a lot so I looked at the blades-- looks like they're currently stuck at about 90 degrees to each other. One points radially out from the hub and the other is 90 degrees to that.
Should the blades be able to swivel freely about their mounting bolts, or are they supposed to be fixed in place, spinning only with the blade pan, around the hub?
Should I loosen the blade mount bolts or just whack the blade with a mallet to loosen it up?
The manual shows a couple photos where the blades are drooping parallel to each other (and not radiating from the hub): not what I would have expected, but I'm a newbie.
/ Should blades swing freely? #2
The blades on all of our cutters move freely. Notice the blades on our renters' cutter.
/ Should blades swing freely? #3
the blades should swing free.
DO NOT!! loosen the bolts.
rotary cutters use shouldered bolts and when torqued properly, there should be clearance for the blade to move.
check for twine, fencing or plant debris sticking the blade.
post back
/ Should blades swing freely? #4
I was going to sharpen the blades on my King Kutter rotary mower when I noticed the bolt/nuts that held them had been spot welded together...looked factory done. I assume I remove the entire lower blade assembly with the center hub if I want them off to sharpen or try with them attached.
/ Should blades swing freely? #5
many mowers have an access hole int he deck to get at the nuts. if there is a spot weld.. you just grind that out first.
I'd never take a hog blade off to sharpen it. :) If I'm going to the trouble to take a blad eoff.. a new ones going on! unless they are new and I'm taking the pan off for seal or bearing repalcement ont he output shaft or soemthing like that.. etc..
/ Should blades swing freely? #6
Like pappy always said..."you don't want to cut weeds, you want to severely beat them!":)
Thanks for the help -- there was a wire/cable wrapped around the bolt. Removed it and now it spins freely.
/ Should blades swing freely? #10
i leave mine with a 1/16 flat busts a weed stem good.. helps kill it
/ Should blades swing freely? #11
I want to put new blades on my Frontier RC2048 rotary cutter. I removed the nut, but the bolt is fixed in place somehow. How do I get the bolts out of the drum so I can replace the blades?
/ Should blades swing freely? #12
On my King Kutter rotary mower the main nut is tack welded. Mine is a brush type mower and the blades shouldn't be sharp.
2015 Ford Escape Titanium AWD SUV (A61574)
2015 Ford Escape...
JOHN DEERE 2040 TRACTOR (A63291)
JOHN DEERE 2040...
ROANOKE G195 BRUSH-AX LONG ARM MOWER (A63291)
ROANOKE G195...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2023 Cat 259D3 Skid Steer (A64194)
2023 Cat 259D3...
