Shortened ROPS - WHY???
/ Shortened ROPS - WHY??? #21
low areas.. mean under limbs that would shave the operators head off at his shoulders?
Almost looks like a rops for a ZTR.. can't see them being usefull for a backflip.. as you neck is still gonna snap.. might help some on a side roll.. so I guess the deal is as soon as you get into a fault.. be praying for a side roll :(
soundguy
It could happen......
WHY?
It seems there are so many people on here that are to uptight when it comes to these things. Are you saying you would nover or have never operated and old 8n, 9n, 2n, or ay older fafm tractor for that matter?? It makes you wonder how anyone ever got anything done without them.
When I bought my l3400 4 years ago, it was the first tractor I ever owned with a ROPS. It was not foldable either. I had it off of the tractor before I ever hit 5 hours. It was constantly catching branches in the woods and when mowing, not to mention it won't fit in a 7' garage door.
You just have to use common sense and know the limitations of your equipment.
And since I am already going to get a hard time about this statement from the saftey police, I will also add that I removed the little flip up PTO shield as well. It only lasted until the first time I tried to hook up the pto shaft. It was just a PITA.
Not to mention I also disabled the saftey switch in the seat. I always used to bushhog with the 8n. Being able to stand up to see better, and avoid branches, as well as stretch a little was something I didn't relize how often I actually did it, until I got the bota and it kept turning off. But I did good, this one made it about 15 hours before being removed.
IMO all of these saftey features tend to make people feel TOO comfortable. As if noting can hurt them on their "safe" tractor. A lack of some of these things tends to make people a little more cautious. And the ones aren't...............well I think thats called natural selection.
In my younger days I did operate older tractors (that I didn't own) without a ROPS. Being older and wiser, I would not operate one now without a ROPS. That's just my choice. In fact, the first tractor I owned myself was an '81 JD 750 made before the fed's started requiring a ROPS. First thing I did was go to one of my JD dealers and order the ROPS for it. Cost me $300 but I feel my well being and sense of security were worth it. True, a ROPS doesn't guarantee you will NOT be injured in an accident, but I think that statistics show they do increase the safety factor. If you wish to take your ROPS off, and/or disable the safety switches, that's fine because that's your choice and you'll get no complaints from me.
/ Shortened ROPS - WHY??? #23
What's the difference between that and a folded down ROPS? If you had to mow what I mow, you'd realize that mowing with a folded ROPS presents far less a risk than a rapidly churning chainsaw blade that would have to be used to eliminate every low hanging item I mow around.
If the guys lawn is flat and has tree limbs, I think the risk of snagging a branch with the ROPS and flopping over backwards would be higher than the chance of gravity suddenly letting up and allowing the tractor to float up, turn upside down like Discovery One, and then slam violently into the ground when gravity mysteriously returns.
if that is the only method you can forsee for that tractor to roll.. IE. catastrophic loss of gravity, then return of gravity.. then you need to expand your imagination.
What about say.. an old septic tank in a yard where the tractor fell in to the side when the lid caved in.
soundguy
/ Shortened ROPS - WHY??? #24
soundguy
Kinda the same answer someone gave me when they made "first assumption" on seeing me and my boy on my ex-TZ25DA while crossing a pond and thinking we were going to fall into a subterranean world hidden by the 8" of murky water.... I know my swale and rest of the property better than those who have never seen it.
/ Shortened ROPS - WHY??? #25
You'd be surprised.. especially about 'dry ponds' and what not.
I HAVE falled and sunk into muck covered by 2" of crust. Have went in past axles.
not that it will always happen.. but only needs to happen once to be a problem.. that's the nice thing about a constant safety device. don't have to see the future to engage it right before the accident happens,.
soundguy
/ Shortened ROPS - WHY??? #26
It's nice that tractors now come with ROPS as standard equipment, but for those of you who wouldn't use a tractor without one, I have a question?
Do you ALWAYS were your seat belt?
Just having a ROPS and not wearing the seat belt, seems to me, to be giving the operator a false sense of security. They are designed to be used together for proper protection.
/ Shortened ROPS - WHY??? #27
false security, and just another large metal thing to crush or pin you if you aren't held in the seat.
I just added a rops to my 35 year old ford tractor.. with drivers ont he road texting and not paying attention.. it makes me feel better.
soundguy
/ Shortened ROPS - WHY??? #28
I follow what is called out in the Operator's Manual.
The Deere operator manuals state to use the belt if the ROPS is erected, but not to use the belt if the ROPS is folded. I expect you'll see this comment in most tractor operator's manuals.
To get my 4400 in the garage, I have to fold the ROPS, so my drill is to pull out of the garage (not belted), unfold the ROPS while the tractor is warming and do a walkaround "pre-flight".
The folding ROPS is a bit of a pain (my previous two machines didn't have a folder), but that task is part of the price of ownership.
And, once that ROPS is up, the seatbelt goes on.
/ Shortened ROPS - WHY??? #29
i have a jd770 which is a fairly small tractor. the rops on that interferes with a standard 7' high garage door. i was able to get by though, because i could push the door up a couple extra inches as i went under. if i had needed more clearance i would have had to do something more drastic.
let's face it, just do a search on here of any rops threads and you will see the same thing. if the owner had made it folding instead of just shortening it, the safety gestapo in here would have thrown a fit because it wasn't the manufacturers liability more. ld1 got it right - how did a lot of you ever get anything done in the days before rops were standard?
/ Shortened ROPS - WHY??? #31
soundguy
you mean added a rops to the ford 8000 ya have? i considered doing to my ford 8000 but was a bit pricey, and i know some will say ya cant put a price on safety etc, but anyhow what did it cost ya if ya dont mind me asking? new or used was it?
/ Shortened ROPS - WHY??? #32
Actually i put them on my 5000. got a used set from the local auction. cost 159$ plus a couple weekends of sweat equity. came with a nice big aluminum topper and some serviceable flat top fenders.
soundguy
/ Shortened ROPS - WHY??? #33
First off, Safety police, Dont Scold me....I've got a cabbed machine so my rops is permanent :thumbsup:
But riddle me this....
Foldable Rops...if a person has to fold the rops to get it in the garage and NEVER unfolds it because its a PITA...whats safer....shortening the rops so it fits in your garage at the new "max upright height" or just keeping the rops folded down?
Yeah, keeping it factory is best..but I KNOW this is s scenario that is VERY true. I know in my travels I see it all the time..IMO cutting down the ROPS to a height that fits in your garage so you can keep it up is better then nothing.
/ Shortened ROPS - WHY??? #34
Is there any statistic that shows that 8' garage doors became more popular with the increase in smaller "homeowner" tractors with ROPS?
/ Shortened ROPS - WHY??? #35
I think If I was building ( not buying ).. I'd make my garage door rops compatible.. can't add too much to the construction phase.. vs the utility and safety it will offer down the line.
soundguy
/ Shortened ROPS - WHY??? #36
I would say they came with soccer moms driving SUVs.
As for the other question about seatbelts. I ALWAYS wear mine. It's easy enough to do. First thing I do when I sit down.
/ Shortened ROPS - WHY??? #37
ditto that.. keeps me from falling out when I hit a bump.. :)
soundguy
/ Shortened ROPS - WHY??? #38
It really depends on how good a welder the guy is...
Although folding and erecting the ROPS is a bit of a pain, I don't operate my tractor without erecting the ROPS. Part of the job...
That said, I'd rather have a modified (shorter) ROPS then run with a folded ROPS.If I was to modify a ROPS, I'd find some square thickwalled tubing that would fit inside the ROPS tubing, bolt that to the lower and upper sections of the ROPS, then weld the sections complete (BTW, bevel the sawn ends to get a good, full penetration weld).
/ Shortened ROPS - WHY??? #39
soundguy
actually, it's probably quite a bit of an extra cost. 7' doors are/were the standard, mainly because an 8' wall is the standard. if you have a rops that requires more height, you have no choice but to go with a higher door, and that will always require a higher wall. you'll have to go to 10' studs and then cut to the length you want. more expensive studs, more sheathing, more siding, more vapor barrier... basically everything you used will need 10%-25% more material - oh yeah. more labor too.
if you had thought ahead to have higher ceilings, but still used 7' doors, i just gotta ask... what were you thinking? :D
/ Shortened ROPS - WHY??? #40
Never heard of 9' studs, Eh?
CAT IT28B Cab (A68134)
PORTA POTTY (A67714)
Mercury Black Max 150HP Outboard Boat Motor. (A66738)
Mercury Black Max...
John Deere 6410 (A64911)
John Deere 6410...
2010 GMC SIERRA 3500HD (A67714)
2010 GMC SIERRA...
2010 . TRIAXLE LOWBOY (A67714)
2010 . TRIAXLE...
