Short videos of L39 Movin Sandstone
   / Short videos of L39 Movin Sandstone #1
yekrut
Paris, Ohio
Bolens (Iseki Deisel) G214
   / Short videos of L39 Movin Sandstone #2
Loader and grapple worked great for moving the rocks.
   / Short videos of L39 Movin Sandstone #3
Just curious, what's your loader's capacity. Nice pics.
   / Short videos of L39 Movin Sandstone #4
Nice! Those blocks look pretty beefy, any idea of what one weighs?
2200lbs bucket mid point to Max Height
2762lbs pivot pins to max Height
Those are the factor settings. I know some have increased this some on their L39's. Mine are still at factory settings. One of the benefits of the LD Millonzi 48". It's very light so I don't lose much lift. I can lift more with it than my standard FEL bucket. I know some of the HD skidsteer grapples weigh 800-1000 lbs. While I'm sure they are tough as he** I wouldn't want to lose the lift.
Not real sure. I'd guess the one in the first video is 1500+lbs. I had one that I could barely lift. I couldn't lift it out of the truck but once I got it on the ground I could lift it about 2ft off the ground and that was it. It is a whopper. I'd say it was pushing a ton. Maybe more.
   / Short videos of L39 Movin Sandstone #7
Nice vids. Looked like in one of them your back tires where slipping a little while backing up. Where you using the 4WD?
Thanks. Don't recall slippin at all. I was in 4WD. It may be the frame rate on the video. I did hit a little higher gear in reverse than I meant to when I was turning around in the first vid. That may be what you were referring to. I was lowering the BH trying to make sure I didn't hit one of those limbs behind me.
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
2019 JOHN DEERE 8295R LOT IDENTIFIER 170 (A53084)
2019 JOHN DEERE...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
