Short videos of L39 Movin Sandstone
   / Short videos of L39 Movin Sandstone #1
yekrut
Paris, Ohio
Bolens (Iseki Deisel) G214
   / Short videos of L39 Movin Sandstone #2
Loader and grapple worked great for moving the rocks.
   / Short videos of L39 Movin Sandstone #3
Just curious, what's your loader's capacity. Nice pics.
   / Short videos of L39 Movin Sandstone #4
Nice! Those blocks look pretty beefy, any idea of what one weighs?
2200lbs bucket mid point to Max Height
2762lbs pivot pins to max Height
Those are the factor settings. I know some have increased this some on their L39's. Mine are still at factory settings. One of the benefits of the LD Millonzi 48". It's very light so I don't lose much lift. I can lift more with it than my standard FEL bucket. I know some of the HD skidsteer grapples weigh 800-1000 lbs. While I'm sure they are tough as he** I wouldn't want to lose the lift.
Not real sure. I'd guess the one in the first video is 1500+lbs. I had one that I could barely lift. I couldn't lift it out of the truck but once I got it on the ground I could lift it about 2ft off the ground and that was it. It is a whopper. I'd say it was pushing a ton. Maybe more.
   / Short videos of L39 Movin Sandstone #7
Nice vids. Looked like in one of them your back tires where slipping a little while backing up. Where you using the 4WD?
Thanks. Don't recall slippin at all. I was in 4WD. It may be the frame rate on the video. I did hit a little higher gear in reverse than I meant to when I was turning around in the first vid. That may be what you were referring to. I was lowering the BH trying to make sure I didn't hit one of those limbs behind me.
2021 JOHN DEERE 1725 CCS LOT IDENTIFIER 29 (A53084)
2021 JOHN DEERE...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
