Shopping
/ Shopping #1
buffalobutt
indiana USA
Hi fellow tractor enthusiast
I have been in the background for a few weeks and decided to come out so to speak.
This site has been very helpfull because before reading many of the comments on this site I was pretty much in the dark about compact tractors.
I am about a month away from a purchase but I am pretty much set on the Kabota BX22.
I am hopeing that the BX22 will allow me to tier the rather steep hill on my property and make it more usable.
I would very much appreciate any comments from you folks out there about the BX22
Loads of thanks!!
/ Shopping #2
you don't really tell us what u expect the tractor to do? what are the jobs that u will mostly use it for, how much land and what type of land? hard to give a valid opinion without his info.
/ Shopping
Frank_F15, Thanks for the feedback.
I have a hill that is about 150 feet wide and from crest to the bottom is about 200 feet. The slope is maybe 45 degrees. I need a tractor that will handle the incline and allow me to dig trenches vertically every 25-30 feet so that I can pour a footing and then build a retaining wall, once that is done I need to back fill each tier so that I can use the hill. I think the soil has a lot of clay so the digging is going to be harder than usual. Also I want to remove an existing blacktop driveway, which is about 75 feet long and 20 feet wide, and replace it with cement.
/ Shopping #4
If I understand your planned retaining wall and you are looking to take the tractor on a 45 degree side slope to trench footings, you will be disappointed. Most everyone agrees that 15 degrees on a side slope is about as much as you can safely handle. Even at that, the pucker factor will get your attention. Forty-five degrees would have to be handled with track equipment. Be careful.
MarkV
/ Shopping #5
the bx22 is a fine machine, but i think you may be overextending it's capabilities. 45 deg. is one heck of a slope and am certain that u can not do what you want to safley!
/ Shopping
Frank_F15 & Markv
I am going to have to take a measurement of the incline but I think 34-45 degree range is what I will be dealing with, but I will post after the measurements are more accurate. Some areas are steeper than others though so maybe I can work the steeper areas from a safer spot. I just don’t know. Did not mean to be unprepared but I had know idea that the incline might be a problem. Hey angles aren’t my thing! 15 degrees seems safe and maybe 20 if your careful? Markv, what do you mean by side slope? I don’t think that I would need to work horizontally without preparing the ground first because from the outer edges I could get to some of the steepest areas. Heck after I take the measurements I will also post a picture from different angles to see what you guys think. Funny thing is that I have brought up the steep hill to several dealers and not one said that the tractor is not capable of doing it. I have talked to Kubota, Cub and Kioti and nobody seemed to have any concern what so ever, (GO FIGURE!)That pucker factor is definitely an important consideration and I have been dropped on my head a few times but I ain’t stupid at least not just yet! Boy now I’m in a quandary! I had the little woman convinced that I needed a tractor to finish the hill so if I find out that I can’t, I’ll have to come up with some other justification, (any ideas)? Hey maybe some roses eh?
Thanks very much for your assistance.
Buffalobutt
/ Shopping #7
Side slope is when you drive parallel to the hill, i.e. not going up and down. You can go up and down a much steeper incline than you can go across it. I've got a hill here that averages around 30 degrees or so. I drove straight up it, then straight down it, and it wasn't a big deal. Turning at the top, even though it's a relatively flat spot, was more excitement than I want. It's ATV country. 45 degrees going up and down might still be a challenge, depending on weight distribution and traction.
Kevin
/ Shopping #8
Sounds like I misunderstood your intentions on the slope, sorry. I was visualizing retaining walls parallel with the top to create terraces. In my mind I was seeing you with one side of the tractor on the downhill side and the other on the uphill side digging footings across the slope. With a 35 – 45 degree slope this would not be good thing./w3tcompact/icons/eyes.gif As a general rule, that varies depending on the tractor and equipment attached to it, 15 degrees for a side to side crossing of a grade and 30 degrees for an up and down approach is considered the safe working limits. Keep in mind that a backhoe adds a lot of weight above the center of gravity on a tractor.
MarkV
Brake Drums (A62613)
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
JOHN DEERE 1210A GRAIN CART (A64277)
JOHN DEERE 1210A...
1995 Kiefer Built Gooseneck Trailer (A66285)
1995 Kiefer Built...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
