Shibaura Sp154
/ Shibaura Sp154 #1
armyof1
Bath Co Va
GC1720
Yes My Shibaura Sp154 oil level is way over full and the tran way low. Where do I need to start at the Hyd pump on the side of motor are split the tractor. Thank for any help Sam
/ Shibaura Sp154 #2
Your hydraulic internal seals are blown. There are not parts available for the hydraulic pump. I can supply a pump from an aftermarket supplier at a cheaper cost than from the manufacture or I also have a used pump.
/ Shibaura Sp154
So are you saying the Hyd pump on the side of the motor has bad seals. If so why can't it be match up for new seals
/ Shibaura Sp154 #4
The shaft seal can be replaced , but it is not made to hold the hydraulic pressure. Most manufactures do not supply the internal seals . When they blow the pump needs to be replaced.
/ Shibaura Sp154
I going to try and rebuild it. Where I work at we do Hyd work all the time. I will mic the seal and see what I can come up with. And if I can't rebuild it I will buy one from you.
Sellick S80 (A60462)
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
INSPECTION (A65583)
INSPECTION (A65583)
2022 EZ-GO ELITE...
