Shibaura Sp154
   / Shibaura Sp154 #1
armyof1
Bronze Member
Bath Co Va
GC1720
Yes My Shibaura Sp154 oil level is way over full and the tran way low. Where do I need to start at the Hyd pump on the side of motor are split the tractor. Thank for any help Sam
   / Shibaura Sp154 #2
Your hydraulic internal seals are blown. There are not parts available for the hydraulic pump. I can supply a pump from an aftermarket supplier at a cheaper cost than from the manufacture or I also have a used pump.
   / Shibaura Sp154
So are you saying the Hyd pump on the side of the motor has bad seals. If so why can't it be match up for new seals
   / Shibaura Sp154 #4
The shaft seal can be replaced , but it is not made to hold the hydraulic pressure. Most manufactures do not supply the internal seals . When they blow the pump needs to be replaced.
   / Shibaura Sp154
I going to try and rebuild it. Where I work at we do Hyd work all the time. I will mic the seal and see what I can come up with. And if I can't rebuild it I will buy one from you.
2010 Freightliner M2 106 Crew Cab Dump Truck, VIN # 1FVAC2BS5ADAP9253 (A51572)
2010 Freightliner...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
ITEM LOCATION (A53084)
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
