Shibaura 3 point tilt adjustment
   / Shibaura 3 point tilt adjustment #1
bshwhckr10ga
Cole Camp, Mo
Shibaura D23
I have a Shibaura D23F the 3 point tilt adjustment is stuck in the up position. The electronic panel shows a green light like it is working,bu the hydrolic cylinder will not go down. Any suggestions how to fix this issue would helpful.
Thanks
   / Shibaura 3 point tilt adjustment #2
Does the rest of the hydraulic system work?
If the tilt cylinder is operated from the rear remotes, swap it with the toplink cylinder.
All the hydrolics are working. The tilt cylunder does not seem to be getting the down command from the adjustment/computer box. Is there a resistor or selinoid in this box that could be causing the issues?
Danuser Digger F-8 (A53472)
Danuser Digger F-8...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
