Shibaura 3 point tilt adjustment
   / Shibaura 3 point tilt adjustment #1
bshwhckr10ga
Cole Camp, Mo
Shibaura D23
I have a Shibaura D23F the 3 point tilt adjustment is stuck in the up position. The electronic panel shows a green light like it is working,bu the hydrolic cylinder will not go down. Any suggestions how to fix this issue would helpful.
   / Shibaura 3 point tilt adjustment #2
Does the rest of the hydraulic system work?
If the tilt cylinder is operated from the rear remotes, swap it with the toplink cylinder.
All the hydrolics are working. The tilt cylunder does not seem to be getting the down command from the adjustment/computer box. Is there a resistor or selinoid in this box that could be causing the issues?
UNUSED CHERY INDUSTRIAL 11' CATTLE SQUEEZE CHUTE (A51248)
UNUSED CHERY...
UNUSED CHERY INDUSTRIAL SINGLE GARAGE METAL SHED (A51248)
UNUSED CHERY...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
UNUSED FUTURE GR87 87" ANGLE GRADER BLADE (A51248)
UNUSED FUTURE GR87...
Troy Bilt Gas Powered String Trimmer (A51573)
Troy Bilt Gas...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
